g'day guys
will an rb25det out of an r33 bolt in directly to an r32? and if i did so would i have to get a custom made exhaust and intercooler?
cheers keegza :P
have you got the engine already?
- check the difference in the way the engine mounts bolt on the block , if they look the same you should be able to retain the 32 mounts and bolt them to the RB25 block.
have you got a front mount IC or using std?
- after market one should be pretty close in the piping design so you should have to change much here.
exhaust would more than likely need a change, but the std dump will fit on the 32 exhaust, you will only know once you fit the engine in.. but this change would be very little in terms of cost for modification.
Sorry to hijack your thread Keegza, but I'm also looking at doing something like this...
I have an R32GTS with an RB25DE, and am looking at converting to an RB25DET most likely from a half cut. What other things would i need to look at changing as well? I know of brakes for a start, but i was also told the RB25DET computer wouldn't be able to run the utilities in the car (A/C etc..) is this so? and what else should i think about replacing as well.
Thanks guys.
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
    • Nah. H2S. H2S is "rotten egg gas", which is what is associated with no cat. SO2 is equally nasty, and if you've ever smelt it you'll know all about it. More of a choking, acid in the back of the throat sort of thing. But you can only smell it in a narrow range up to about 1ppm. Above that, it irritates your mucous membranes, but you don't smell it.
    • Kicked the 34 in the guts, she won’t be seeing the road till I get the 31 mobile again.  wont be long and she’s a bit of a garage princess anyway haha
