Ive searched and searched...
anyways i managed to take my climate control apart in my 32 and took the lights out.. they seem to be small lights with blue covers on them....
went to jaycar for some 3mm leds and put them in but they blew right away....
anyone got any other suggestions?
thanks
ed
https://www.sau.com.au/forums/topic/87612-climate-control/
  • Replies 78
those tiny bulbs are $16 each from nissan australia.they have to be imported directly from japan!
from memory i think there are six in there(not counting the green LEDs for recycle and demister)
i wanted to do the same with LEDs but not sure of the resistor size..
https://www.sau.com.au/forums/topic/87612-climate-control/#findComment-1601511
$16?? Do you have a pic of one of the bulbs? Or can you take a pic of one next to a 5c piece?
I'm about to do the same thing in my R33, and there's no chance i'm paying that much for those globes.
Don't forget that Nissan are the same people that want $189 for an 02 sensor! ;op
https://www.sau.com.au/forums/topic/87612-climate-control/#findComment-1604122
the globes are very small,and u cannot get anything like them in aus.belive me i tried,plus the small blue plastic caps on each bulb which give the white/green colour are almost allways melted on and impossible to remove without splitting them.i think the only option is LED.
ill post up a pick in the next day or so.
https://www.sau.com.au/forums/topic/87612-climate-control/#findComment-1605962
Simon,i dont think the jaycar city store have the facillities to solder the resistors and leds in...im sure they would gladly work out the risistor value needed but u would have to solder it yourself unless u took it to an auto/electrician and paid them.
They would likely charge 1 hour labour which would cost around $60-80 so it would be cheaper to get the bulbs!
https://www.sau.com.au/forums/topic/87612-climate-control/#findComment-1606397
the bulb caps are not green..they are blue and thats how nissan achived the pale green/white look they give off.the only green lights are the two LEDs to the far right which are the demister and circulate buttons.; )
By the way you can replace the light which is in the drivers power window button.
not many people know its there as they are often blown by the time we get the car over here..i got one from jaycar for $2.95 and its been goin strong for a year now!
Be carefull when you remove the blue cap as they easily split, then it wont match up to the rest of your dash lights!
https://www.sau.com.au/forums/topic/87612-climate-control/#findComment-1610540
OMG! I pulled my climate control unit out (EASY!) when I put my stereo in a couple of days ago. I actually unscrewed those two bulb and looked at them, stuck them back in and left it at that.
I thought they were bulbs until I saw the rubber cap on them... that woud just insulate the heat of the globes.
Now I know that they are the bulbs, I might pull the caps off and have a look at the globe. Anyone else seen them with the caps off? The globes are definately not little wedge bulbs or anything?
https://www.sau.com.au/forums/topic/87612-climate-control/#findComment-1613838
there are more than just two..infact too get at all the bulbs you will need to take apart the climate control box itself.inside you will find another four or so (cant remember exactly)
check out the car audio australia forums where there is a very recent thread on wiring up LEDs in series using 12volts and a few well placed resistors.
these LEDs will be the only practical replacement for the bulbs,unless you don't mind paying $16 per bulb!
https://www.sau.com.au/forums/topic/87612-climate-control/#findComment-1613930
oh ok! I started pulling the box apart, got to the PCB and thought again... there wasn't much I could do about it without replacement bulbs. =-[
So the two on the side that I unscrewed without dismantling anything... what do they light up? My Commodore had a similar deal with using a few bulbs to light up an entire panel of switches, so I thought that was what it was doing, as ALL my bulbs in the A/C unit do not light up. (except the demister green rectangle and something else the same)
https://www.sau.com.au/forums/topic/87612-climate-control/#findComment-1614967
OK, it DOES have that setup that I mentioned above.
I just noticed driving last night, that since I unscrewed, inspected and re-installed the TWO bulbs (accessible withought opening anything) that exactly half of my climate control unit is now lit up!
Basically all the buttons on the left run off one bulb (up to and including the temp down button) and all the buttons on the right run off the other. Turns out that one of my bulbs was fine, but had a loose contact.
https://www.sau.com.au/forums/topic/87612-climate-control/#findComment-1619696
Randy, Do you have a picture of the globe, im sure I could source them globes cheaper then $16 each.... Sounds like nissan is having a go at its customers.
We have some good suppliers, im sure we could find a globe to match.
Cheers
Sumo
P.S. Dodgy auto electricans will charge an hours labour for a 15 min job. Honest ones dont.
https://www.sau.com.au/forums/topic/87612-climate-control/#findComment-1620644
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
