there a standard dick smith job replacement, blue leds look good on the recycle and demist buttons cos ive done that already, but dont use leds for the main lighting, it wont light up properly because blue leds have a very narrow lighting angle
yeah, in my article I put a note at the bottom, telling people to sand the led lense abit to help disperse light.
  • Replies 78
the long awaited pics..................................turned out quite sh!thouse unfortunatly :rolleyes: , ill post anyway
The photos dont do them justice because im crap at taking decent pics - the camera in my phone is about the best i can do <_<
  • 6 months later...
sorry to drag an old thread up.....
I have searched the web and found a supplier with incandecnt and led options for climate control and instrument light in a range of colours
autolumination.com
the #74 and neo-wedge look like they will suit, can anyone confirm sizes for R33?
doubtful. The bulbs need a fair amount of wire on them to coil onto the original holder, which looks nothing like anything standard.
I thought Narva.com.au might have something, but none of their globe-holders will work either!
There's another thread somewhere on this topic too.
Today I put new grain-of-wheat globes in, with blue silcone caps from Narva. It lights up a dim blue...
I also fixed the demister and hazard button lights, which had similar rubber caps on them. My blue looks like N1GTR's picture above, whereas the blue cap on the hazard bulb makes the icon light up a nice bright white. Very similar white to the tacho/speed guages.
Damn Nissan and their special globes, globe-holders, and silicone caps! I will never get this fixed! =-///
I wonder what the current s15 and other nissan models are using these days...
Im sure they would have completely changed over to LED's but if not then maybe theres a chance they are using the same type still...does anyone know?
If you follow the link in my post, the neo wedge holders halfway down the page are complete assembly with the grain of wheat bulbs in many colours. The #74 bulbs are for the dash backlight and also available in LED
These are used in Sentra and Maxima in the USA .... so I was asking do they look the same and how is size compared to R33s before I order some.
  • 3 months later...
Sorry to dredge up and old post but has anyone gotten hold of these globes, been to several stores and cant find them including dick smiths, jaycar etc. Anyone is south australia found them? The alternative of paying around 20 for a tiny globes is ridiculous
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
