Hey Guys,
My car has been at the exhaust shop for the last 7 days getting the following exhaust system bolted onto my stock GTR:
- 3" Stainless Steel Dumps
- 3" Fabricated Front Pipes
- 3" Mandrel Bent Piping
- 3" Hi-Flo Cat
- 3" Muffler
This is an upgrade from the stock exhaust system which was shagged.
I went for a 3" System because I believed that the low down torque and response would be better than a larger 3.5" sized system. The guys spent a lot of time doing it and there was a few minor setbacks (rusty old exhaust system was hard to get off the turbos etc)
The car sounded pretty good of course, so I jumped in it and the first thing I noticed was the complete lack of power. The thing feels as though its bogging down under full throttle, sure it has an underwhelming amount of life in the 4,000 - 7,000rpm top end, but anything under that and it is hopeless!
The popping is a lot louder and it just seems to be trying a lot harder for bugger all difference in performance.
Can anyone offer some light on my situation?
https://www.sau.com.au/forums/topic/87616-new-3-exhaust-system-no-power/
Thanks for the suggestions guys, I reset my ECU (unplugged the battery and stabbed the brake pedal several times, then reconnect it) .. mild improvement but still just as powerful as the car was before the exhaust.
The exhaust fitter said he had to slightly customise the dumps to accomodate the o2 sensor.. maybe its that. I'm dropping it back in tomorrow morning.
out of interest what do the custom dumps look like? is there a particular reason you went custom over the available off the shelf dumps? is it possible the new cat is causing a restriction? what type of cat is it?
also have you had the car dyno'd before? if so dyno it now and see what happens.
Also, just out of interest how much was the exhaust? and mild or stainless?
They where off the shelf dumps, and other than the muffler the rest was custom.
Dyno, no, I havent yet. I already can feel a problem with the car, i'd rather take it in when its healthy! which i will do once this problem is sorted.
All up it cost $1700 at mates rates.
Pentae - I have the same sort of modification to my exhaust system except I have 3.5inch back from the cat, but I don't have any aftermarket dumps. I am running 14psi boost and this gave me an extra 60KW at the rears assuming standard is around 170KW. So you should be feeling a big difference! As for below 4000rpm didn't have the chance to drive the standard exhaust system, but mine is pretty sluggish too until i hit boost at about 3500rpm.
yeah, 3.5inch would have been better than 3inch. a smaller exaust will only rob you of performance, it won't give you any advantage in throttle respose or low-down torque.
In N/A's maybe, as backpressure is required, however in turbo's the turbo creates ample backpressure
If you are experiencing lack of power. TAKE IT BACK and tell the guy who installed it all. As they haven't done their job properly if this "upgrade" is giving you poorer performance.
  • 4 weeks later...
i had twin apexi air filters and SS dump pipes and 3in turbo back exhaust fitted to mine
HUGE difference
stock ecu and all that, the with exhaust and intake mods stock boost jumped to 14 psi
and can feel boost about 2700rpm full boost by just before 3500rpm
also i havent dynoed but will have just over 200awkws
so somethings wrong in urs
good luck
RellikZephyr
