yeh like sl!m said.. check for rust under it and under where the spare wheel (space saver in the boot) is.. i think there the main places. oh near where the front bonet hinge is and where the front roof piller meet, check all around there. saw one car and it had rust there.. not good. oh and if the window seals are coming up on the edges at the bottom of the front window, that happens when every skyline ive seen.
theres quite a few things to look for, but theres a few to get ya started :)
If the car has aftermarket suspension, and looks low. check under the car make sure they havent bottomed out, and damaged somthing underneath.
trying to think of what else is easier to check, I've never shopped for a 33 so dont know what normal probs they have :lol:
Take a look at my GTS for sale on carsales...
Its white R33 GTS for $13k with heeps of extras and nothing to spend, im a SAU member and i have looked after my car as much as most people in the club!
Cheers,
Mitch
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
