Hey guys just wondering what you think the best sounding exhaust is for a r33 gtst.
I will be after one soon and want something that is not 'TOO loud' and not droany on the freeway.
Cheers.
Edited by Paradizzle
https://www.sau.com.au/forums/topic/87672-best-sounding-exhaust/
I recently sold a Blitz Nur Spec cat back which sounded great! it just had a res and rear cannon with silencer.... super quiet on the freeway...
I now have an Apexi N1 which as a mid muffler and a rear cannon, it has a deeper note with more drone on the freeway but i dont have the silencer installed...
Hope that helped..
Did alot of exhaust work on first turbo car as it had issues. Two things, DUMP and Muffler. Both of those were changed by themselves on seperate occasions with no other changes and they make MASSIVE differences to change in sound.
If you just want sound, just change the muffler.
Front pipe and dump made my exhaust more "deeper" in tone and I suppose you could say its more louder when giving it a hit too.
That said its all personal preferance man. I've heard that the Kakimotos are extra quiet, and having a 5-Zigen myself they are known to be loud. My 5-Zigen Rocket one isn't too loud to be annoying (it's actually quiet from inside the cabin) and is loud enough to sound sweet from the outside and when I give it a hit.
I can't remember what catback my brother had on his R33 but it was the best sounding turbo car I've ever heard. So freaking growly and mean. I'll try to find out for you.
LOL to nismo33's avatar pic,
um yeh as every one has been saying, the main thing is the muffler(s), change or remove some..... i have a trust exhaust system and its not that loud, but now that i removed the resonator, and changed the dump its heaps louder.
You are never going to get a definite answer. Everybody has different opinions on a good exhaust note: witness the huge droney exhausts some people install (and as you can probably guess, I prefer something less attention seeking). Moreover, other modifications can have an impact on exhaust sound so two cars with the same exhaust but different modifications will likely sound different.
I have fiddled around with exhausts on a number of cars and it all depends on the level of muff........
My GTR had a Nismo exhaust - it was incredibly quiet, changed the muffler to a steel Luki sports muffler and it was slightly louder, ended up changing that for a straight through RPS muffler with three inch bore - now sounds beautiful.
You can get a mild steel three inch exhaust made up with a resonator in the tranny tunnel and a straight through muffler on the back for modest money - this should sound right nice!
how long is a piece of string?
my opinion is that my exhaust combo sounds best :)
i think the best option is a free-flowing exhaust with a massive resonator. this keeps the deep sound but removes the drone
everyone is going to have their own opinion here, and every exhaust sounds different on different cars
the blitz nur spec r's are good the drone a bit off boost around 2 - 2.5 rpm which isnt so bad in my 32 because it sits arond 3grand on 100 area very free flowing too. very small resignator worth the cash you pay for it.
HKS super drager sounds great not to quiet not to loud either. The note got deeper and quieter at low revs when I fitted my dump and hi-flo cat.
cheers
A lot of people seem to like the Super Dragers. I've always been a little sceptical of their design given the HKS pipework has some fairly large bends in it (atleast for the R32). I would personally opt for a more straightfoward "N1" style pipework.
I also got the HKS Super dragger muffler with custom 3.5" cat back piping & it was originally fairly quite. But, as soon as I replaced the generic hi-flow cat with the higher flowing barrell type cat it now has a lot deeper & agressive tone.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
    • Try using Penrite 80W140, has Limslip predosed into it
