Get a R31. is right in between cheap comman car and something faster.
They go alright actually, run 16s near stock. Cheap as, parts cheap as, easy to work on, heaps of info, driftable with some work, all rb engines fit..
https://www.sau.com.au/forums/topic/87680-first-car/page/2/#findComment-1592758
The reason so many people like Twin Cam Rollas is because they're so damn sweet.
My little brother used to have one and I loved it. With a 7700rpm redline they love to be abused and if you get the revs right, you won't have any problems beating "vl's and shit".
He took out many cars far more powerful than him partially due to skill and partially due to the opponent not knowing their full potential.
This was the AE82 variety. If I was ever after a small car, it'd be an AE82 Twin Cam for sure.
https://www.sau.com.au/forums/topic/87680-first-car/page/2/#findComment-1592919
I think they only came with one engine (rb30de). Make sure its not a pintara, they look similar. thats the 3.0ltr OHC straight 6 from the vl commo.
Rollas are pretty subjective. The 4age is a solid little engine so if its been owned by a grandma it could be fine at 250,000 but if its been in japan and been given a hard life it might be near dead at 150,000.
Jap ks are double our ks in my opinion. They drive shorter runs, harder. No long roads.
get a compression test done to be sure.
Edited by Boostzor
https://www.sau.com.au/forums/topic/87680-first-car/page/2/#findComment-1594861
Local spec R31 skylines had the RB30e. 3l 6cyl, makes about 115 at the fly. good motor with quite alot of potential.
There was also the R31 pintara, which is the same car apart from the driveline. it had the ca20, a n/a 4cyl 2l. you can see its different fomr the skylines by its grille (amongst other things).
Imports had a few different engines, but mostly the redtop Rb20.
https://www.sau.com.au/forums/topic/87680-first-car/page/2/#findComment-1595585
You can get a Passage or coupe HR31 (import R31) for under $10k with a turbo engine..
With some work, they go as hard as most other imports, and something a little bit different.
Parts may be a bit difficult to track down, but are available.
https://www.sau.com.au/forums/topic/87680-first-car/page/2/#findComment-1596062
    • I have copied the images in the original post from photobucket to the SAU servers to make sure they stay available.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
