Originally posted by Pva_Glue
obvisouly.. you never owned skyline...
cheers
Joe
Hehe... true, but I think that particular Viper's V10 engine (which has a rather nice turbo running at 15PSI + NOS!!!) would pretty much leave the ol' 'line behind. :uh-huh:
The 1000HP dyno-sheet is also rather impressive... :D
https://www.sau.com.au/forums/topic/8771-forget-the-skyline/#findComment-128974
there was a viper getting around here last sunday. nismorick wanted to have a go against it in his gtr butja the old dude wasn't into that kind of stuff. would have been good to see if they did have a go ..... $50,000 vs. $200,000 .... just to see if they are worth the money... personally I'd take a skyline, I'm not fond of anything thats got more cylinders than neccessary ....
https://www.sau.com.au/forums/topic/8771-forget-the-skyline/#findComment-129223
Originally posted by Shrub32
If i could afford a $200 000 car i would be looking to something european! eg 911 turbo, Mclaren F1.
u do know how much Mclaren F1s cost dont u? cause unless u know the guys who make em.... im thinking ur little 200k would buy u maybe wheels and door.
https://www.sau.com.au/forums/topic/8771-forget-the-skyline/#findComment-129609
I dont know exactly, i assumed theyd be around the 200 k mark :P Even so if i was buying a car that much i would be a multi millionaire to even consider it so the extra 200 or 300 k wouldnt bother me at all!
PS Ron dennis and i go way back so he could do me a litlle deal i spose
https://www.sau.com.au/forums/topic/8771-forget-the-skyline/#findComment-129776
Having spent a day driving a 99 RT/10 Viper I can assure you all they are bloody wicked!!! Can you say TORQUE! Mind you with 8.0L’s you'd expect that. The Viper I drove accelerated as hard in 4th @ 60km/h as it did in 2nd. Somebody mentioned understeer!? Try oversteer, mostly power oversteer. The stock 315's aren't hard to break loose with 8.0L's of torque.
The built quality isn't the greatest, certainly not to Japanese standards, but it's not too bad.
Some Viper owners in the US have managed high 11's for the 1/4 stock! Not many complete standard factory cars can do that.
As for this beast, take a look @ the terminal speed on its "shake down" pass - 152mph!!! 10.11 1/4 with 152mph TS….. I'm guessing the 60ft time on that pass was very poor! Probably run on road tyres?
https://www.sau.com.au/forums/topic/8771-forget-the-skyline/#findComment-129812
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
