I'm not too sure I said all those things attributed to me but it's all good.
Nice pic of the R34 with R31House sticker. Mark, you got quoted too.
Pics were - I'm in a couple of times, Reedy's car, 2rismo doing a burnout, closeup of N2O sticker and another taking off down the strip. MSP25T with bonnet up, silver-gtst, Andrea/Brads RB26 S14 doing a MASSIVE burnout, all of us standing around at the driver briefing, TWO.06L, UREADY, someones engine bay with sort of mauve valve covers (RB26) and some rotors.
  • Replies 41
holy shit
so who here bought the mag?
i am home sick today, so i went and bought the mag. after having a squizz, i checked out the free dvd with it.
and i dont care if anyone here tells me to respect other people./ but what absolute f&^king trash. i have never seen such faecal matter before. tell me you also think it is tragic.
holy shit
home sick again eh? you bludger.
nothing that bad i guess. just appeals to a different market than us. but check out the interview wityh the owner of the r33 gts-t that is on the cover - brilliant and insightful stuff
anyway i should not go on bagging the magazine.
have a lovely day
  • 3 weeks later...
Hey. Just noticed something.
Who's the goose on page 100 in the left lane. Only gets a 15.520 at 93.77mph. :lol:
Oh ........ ;)
Well, it was my first run of the day. :D
And if Moanie's is stock, then mine only has half an engine. And I was using four space saver tyres. :D
Enjoy!
El Bee.
ps. Now next time, I predict a fairly dramatic change. ;)
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
