I'm not sure how you could find out...
Quickest unopened rb20 ive seen in the flesh wasnt in a r32, but rather in a mates 260z.
It does mid 12 sec passes with nothing more than intake/exhaust, bigger turbo & chipped ecu.
But I too would be interested to know what the quickest 32 with rb20 does.
https://www.sau.com.au/forums/topic/87736-fastest-r32/#findComment-1585251
I want to see of them pull times before judging how fast they really are :blink:
I was trying to find reference for rb20 powered drag cars in japan. Best I could find was something that did low 11's. I am sure they must have got better than that over the years somewhere.
https://www.sau.com.au/forums/topic/87736-fastest-r32/#findComment-1589790
The fastest GTSt know of running an RB20DET in NZ was running standard internals and did around 12.1 with a huge turbo. There was a GTS4 running RB20DET that ran 11.8 but required NOS to get a launch without bogging.
I think HPI vol 1 or 2 shows a RB"24"DET GTSt doing a ten if I remember correctly.
https://www.sau.com.au/forums/topic/87736-fastest-r32/#findComment-1591027
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
