On the freeway sunday morning I noticed on the AVC-R that I wasn't reaching full boost so I stupidly started upping the boost duty cycle to try and get the right boost.
What happened was that it all of a sudden pinged like a bastard and the engine light came on.
The engine light went straight back off and the car continued to drive fine.
Then I drove it around Wakefield park a few laps but the boost was really erratic. Parked and popped the hood to discover the hose going to the AVC-R was split at the T piece and hissing away.
Obviously that was easy to fix and the rest of the day at the track went off without hitch.
Then monday evening when I started the car I noticed it was idling a little rougher. It's not an uneven idle, just a bleh bleh bleh rather than the smoothness I'm used to. It still drives fine with full power.
Have I broken something?
https://www.sau.com.au/forums/topic/87738-have-i-stuffed-my-engine/
  • Replies 90
mate i don't think it would have done any bad damage in that brief time of running high boost. change in idle sound could be dirty plugs or something similar like that. i would take the plugs out and have a look at them and if you are really worried do a compression test and leak down test.
what happened is the engine over boosted, the ecu detected the rush of air and overfueled the motor. your bad idle is b/c of all the extra fuel that the car dumped when it overboosted has fouled your plugs
Makes sense to me.
Check the code to see anyway adam, then check your plugs :)
Ahh the plugs would have cleaned up on the track I would say. It would also take more than just an over boost rich mixture to foul your plugs. Check your codes and then pull the plugs just make sure their ok ie insulators not cracked also check for tracking.
is the car down on power? or power feels normal?
most likely some sort of electrical related problem but then again.....
best thing to do is a compression test that will tell u straight away if you have properly stuffed it :)
Well I checked with the consult cable and there were no errors!
Strange.
I'll have a look at the plugs on the weekend. If I get up early enough I will do a compression test but I don't know how to do a leak down so I'll have to get someone else to do that.
Car seems to still have full normal power atm.
I would have thought the track would clean the plugs up too.
Maybe they are cracked or something else.
The car runs pretty rich normally. About 10-10.5:1
Strange.
Compression test will show if you done a ringland you dont need a leakdown test for that . To do a leakdown test you need a leakdown tester you cant do it if you dont have one .
Ok I will do a compression test.
I just got another opinion from a quality engine builder.
Not looking good.
Thats what i'm afraid too , you probably cracked a ringland but it will show in the comp test , the suss cil will have lower comp , probably around the 70-100 psi .
Have you noticed any blow-by ? oil in the catch can ?
A bit more oil in the catch can yes. Blow by I haven't noticed.
Thanks Newkleer. Doesn't look like helping though ;)
Duncan - are you saying I could borrow your compression testing gauge if only you knew where it was?
I'm off to the RB30det thread. :):):(:):):)
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
