yes 20s are so legal on a r33 skyline, cops will love you going over 2-3 inchs past the stock wheel size......the ride feels so nice and rough to like rolling on rocks.
the ride with my 20s is no worse than the ride i had with my 18s
size increase has nothing to do with inches over the stock size rim
the rta guidelines state that you must not increase the over all wheel and tyre diameter by no more than 10mm
with regards to "owner certified" modifications
Got any pics of ur car on 20's?
not really champ
everyone has different tastes some people like 20s and chrome wheels and some dont
i dont have 20s cause im an attention seeker i have em cause thats wat a like and thats the way i want my car to look
All good. I do see a lot of people who fit chromes just for attention so thats where my comment comes from.
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
