  • Replies 105
Posted Images
  Ryan D said:
Tried to pm you sydneykid, your inbox is full
Yep, sorry about that, I received more than 100 PM's over the weekend, filled the inbox right up. Cleared a bit of space today, what is it that you want to know?
:D Cheers :D
Edited by Sydneykid
  • 1 month later...
  SkyKC said:
I got 1994 GTS-4, needts to put whole suspention kit, front and rear...how much its gonna cost me?.................
PM sent
:pirate: cheers :kiss:
  • 4 weeks later...
Sorry guys I have been on holidays since the 20/12, I will get around to the hundred or so PM's over the next few days.
All items for R33GTR are currently available.
:) cheers :(
  • 4 weeks later...
SydneyKid,
Would you recommend anything different for a R33 GTR V-Spec? I understand the V- Spec suspension is stiffer to begin with. Would be looking for 98% road / 2% track use.
Thanks!
  tjandriesen said:
SydneyKid,
Thanks!
The V-Spec versus non V Spec diff is minor, 10 mm lower ride height and slightly stiffer springs/shocks. No big deal, the Group Buy KIt is better than both anyway.
:blink: cheers :P
  frankxinyu said:
Hi SK,
what would you recommand if the car is used mainly on the road, but sees the track once in a while?
cheers
The full kit is the go.
The Group Buy kit was engineered (by me) to give a sporty ride for the street and at the same time suite the sorts of things that Skyline owners use their cars for (road drag and circuit). It a great all round kit. For example the R33GTST that won the NSW State Speed Event Championship in 2005 used basically this kit. It was driven from the north coast of NSW to Sydney for the events, raced and then driven the 400 k's home.
:P cheers :)
  JUN R33 said:
Noob question but, will this kit make my GTR's ride softer on the street because the HKS suspension I have now is very bumpy and I prefer a softer ride.
Yes
:sick: cheers :laugh:
  tjandriesen said:
What has it been costing everyone to have the one of the recommended shop do the total install, alignment, etc?
It varies, from $300 to around $500, but that one had some other issues that needed fixing at the same time.
:( cheers :ninja:
Its just cost me $630 just to install front castor, front and rear camber and a wheel alighnment from heaseman steering.......:) (I suuplied the parts)
Cheers
Guest
    • For the record, I hate the colour. Even if I'll never see it again, I know its in there.
    • This is another issue I'm fixing. This little valve stops all the oil from draining to the sump when the engine is turned off. What happens eventually is that the engine is a little noisy and has the oil pressure light on for a few seconds after turning it on. Basically it takes a few seconds to build the pressure when all the oil has drained. This valve is a non serviceable part and is attached to the oil filter housing, BMW suggests to replace the entire housing if this valve fails.  As it turns out this valve can be removed and that means you can get an aftermarket replacement, which I did. The failure, for me at least is that the valve doesn't seat properly after a while, which I've demonstrated. The new one is a ball end and always seats properly.
    • Welp don't know if this is good but I can hear a sizzling sound in my battery Hope I didn't fry it. Turns out a bad battery in the multi meter will give a false reading (likely what happened when I said I had 15x volts), swapped the battery and monitoring now. I'm hoping that sizzling sound is just the equlisation charging
    • Yeah I'm happy to talk to whoever, I don't want to take ownership or even manage it if they don't want but I can probably help with hosting on the sau setup. It's a great resource and should be protected.
    • So, got some bits..   New oil filter housing gasket (main problem I'm trying to fix -see leak above)  While you're in there's: New belts, pulley and tensioners.  Vanos oil line New oil drain valve New water pump and pulley  New fumoto valve (all my cars have these). Some of this stuff seems ok now that I've pulled it out but I still have no idea how old it all is.  The belts looked fine and then I noticed this. Like somebody has hooked it with a pick.
