Yes ANDRA tech regulations require a approved welded in roll cage
but contrary to popular belief......the cage is only one of the requirements
Personal
Full FIA approved race suit
flame retardent undergarments (socks, pants, shirt and balaclava)
ANDRA approved helmet
FIA race boots
Arm restraint/or window net
ANDRA UDL licence
total cost...between $2500-$3500
Vehicle
Roll cage
FIA approved race harness (seat belts)
Belhousing sheild
harmonic balancer shield/or billet steel item fitted
tailshaft loop/loops
rear firewall (if boot mounted fuel system)
battery isolation switch
open ended wheel nuts
ANDRA tech inspection
total cost...between $3500-$4000
So its more than a cage and costs between $6000-$8000 to comply
Sick of reading that people got booted because they didnt have a "cage"
PAUL
DiRTgarage
SORRY STACE LOGGED IN AS YOU
https://www.sau.com.au/forums/topic/87828-the-cage-is-not-all/
You have to do ALL of that if you run a 9.99 - 10.99 second pass ? :D
I was aware of a lot of those requirements, but I always say "without a cage", because thats the primary reason most people never do all of the stuff above, as a cage would be very hard for them to own a car with... the other stuff wouldn't effect it.
However, next time I'll make sure I write.... "Hey got booted for ....." and write all your replies :)
Not complying....simple
PAUL
DiRTgarage
SORRY STACE, LOGGED IN AS YOU
Yep, that's correct.
Thanks for the information anyway... I knew there was much more to it but didn't know the exact specs (as I don't have a 10 second car)
i wish it was just a cage......would have been cheaper
you see my point though...you always hear..."oh he didnt have a cage" generally from people who dont know the rules, or are ignorant to them. Was not trying to put you in your place ThommO just making you and other readers aware that theres more to it than the cage.
PAUL
DiRTgarage
Hi Brad....sorry for the mistake...its Paul. We got the blanket....but should be called scatter shield..as its got cat guts all over it!
Hey Paul, that just proves it's street driven :) It's a big step from the 11's to 10's, we are going to have to decide if we are going to want to race often enough to justify all the gear for tech inspection or just run the time once.
Guest DIRTgarage
ah ok, thanks for confirming that.
as that may be somehting Paul will have to add to his list.
:unsure:
mick
dont think that our set-up will run 140MPH...but we do have 6psi of boost up our sleeve....just in case we need to use it. The boost gives us another 40kw at the treads
are you willing to tell us your goals atm paul for Jambo?
your aiming on competing with Theo & Mark Jacobson?
mid 9s?
i hear Mark has made some more improvements and is wanting low 9s from jambo.
michael
Guest DIRTgarage
mid 9s?
michael
The car wont go any quicker than it has before at jambo. I am running a conservative setup as I only need to make top 16. Yes, i wont be aiming to compete with mark and theo, i will be competing with them. As the elimination is on a DYO handicapped system all cars in top 16 are on a level playing field. No point running the cars guts out in eliminators. Ill be shooting for 9's at the SAU drag day.
Personal
FIA race boots
ANDRA UDL licence
Vehicle
Roll cage
Belhousing sheild
PAUL
DiRTgarage
Yep, that's it. The only thingI would add is that you can get a four point rollbar in place of the six point rollcage which is good to 10.000. For a regularly street driven car this might be a lot easier to get away with.
