Is there usually that much dif between the STI and non-STi? If so, then the only real performance Soobie is the STi WRX.
There is a reasonable difference between the two. For the current 2.0 litre models, the STi gets, amoungth other things:
Bigger (laggier) Turbo
Power uprated from 168kw to 195kw
Torque uprated from 300Nm (@3600rpm) to 343Nm (@4000rpm)
Higher Redline (8000rpm vs 7000rpm I think...)
Stronger 6 speed manual (vs. WRX 5 speed)
Bigger Brakes
5mm Wider wheelbase Front
15mm Wider wheelbase Rear
15mm Longer wheelbase
Lower, stiffer suspension
Active Centre Differential (like the Lancer Evo)
Limited Slip Front Differential
Sticky Tyres
I also heard that the engine internals are stronger in the STi than the standard WRX, and can take more power, which would make sense given the higher redline.
I got this information out of Motor magazine, so don't hold me responsible if it's wrong! Corrections welcome.
  • 3 weeks later...
