So,
Ever since the first stag cruise here in SA ive had a small stone chip on the windscreen (where we pulled of onto gravel between strath and victor as we drove of car in front of me flicked up a rock).
Driving home from work yesterday hurd an ad about how obrien do a windscreen repair for these chips to prevent cracks in future and it getting worse due to heat ect..... though to my self yeah should get it done.
Well today after work jump in car (boiling hot here today 40+deg) crank the A/C... takes a while to get cold as you know and then i feel the refreshing cool on my face and tink tink tink.... your not f**king serious! yeah away it cracked.
Cry cry cry
driving to work this morning, in the rh lane on the freeway, i hear a f**kin BANG! i thought oh f**k thats not cool.
a rock from a truck hit my screen. if i had have been in the middle lane where the truck was, it would have probably hit me square in the face.
good start to the day. as soon as i put a for sale sign on the car, this happens.
keep it
Quick question - do any of these non-oem replacement screens have the de-icer in them? My S1 has a couple of small chips that could almost warrant a claim on my insurance, but the de-icer is my main concern with aftermarket...
did ring obrians today.... turns out they dont have any s1 screens left in oz and they asked for my VIN number so they could get it in from nissan.... does this mean im gonna be up for a grand?
Dunno but when they replaced my windscreen they took down the tint number (apparently there are three or more different ones ) to make sure they matched it. Just ring your local windscreen replacement outfit and if they don't know the answer tell them to find out - shouldn't be too hard.
  • 11 months later...
well was alot easier than expected! Got it replaced thisarvo by InstanWindscreens. Had one in stock here in SA!
My vision is clear as day $395 later, was expecting iot to be ALOT more than that
And today on the way to work.... Another f**king stone chip. Got it booked into for a repair/glue tomorrow morning before it gets up to 38 in the arvo to reduce the chance of loosing 2 in less than a year!
    • Hi again all, I’ve tried doing some searching on the topic but couldn’t find the answer I’m looking for.   I deleted my clutch booster because it had an air leak and was squealing like a hog, and now my clutch has very poor pedal feel and the friction zone is way too small, so I believe I need a bigger diameter clutch master cylinder to compensate for not using the booster. I found a Wilwood option that’s 3/4” for a good price and will fit my 3AN clutch line, but all the firewall adapters I see online such as RB factory or Chase Bays are listed as RWD only (GTST/GTS). Link below. https://rbfactory.shop/products/nissan-to-wilwood-girling-clutch-master-cylinder-adapter My question is if these adapters will also fit a GTR, and if anyone has experience using a 3/4” CMC without the booster, my clutch is a Nismo coppermix twin plate.   Thanks, always appreciate the advice!
    • Catching up on a post, I've replaced the external shark fin with a small 4g antenna (no further drilling, just a 1mm embiggening of the existing hole, and run that to where the dual battery models have the battery in the left rear guard.  No idea what the factory antenna did, but removing it had no impact on anything I use, according to the US manual the GPS antenna is in the dash and it still works fine Also ended up stealing battery power from one of the amps and ACC power from a unit nearby to add an ACC relay to power it. The mounted the booster, wifi, power socket and antenna splitter in the rear left guard out of the way, all out of site with the boot trims in
    • What drama? The only drama you're going to have is the near constant work to maintain all those sphericals. I only have sphericals in my front caster rods and front upper CAs (because both of these are near compulsory in an R32). I have had the front arms out of my car 34 times already this month, and if the new replacements arrive today, I will have them out and apart again tomorrow. Chasing clicking and clunking that comes from sphericals being a.....poor choice for a road car. Moisture and dirt are not their friends. I have been contemplating a change to my rear subframe that would require me to use sphericals in my lower CAs. And.....I don't want to have them that close to the road.
    • Did you need anything else you've already done? If you had it before... and liked the changes after, then supposedly it'd be more of the same. The idea about most suspension arms is to tune geometry that the OEM arms max out at/can't handle because they weren't designed to have the car setup in such a way that 'looks good'.
    • I have replaced everything on my r34 including suspension to Miester R, all rear subframe bushes to poly, all arms to metal adjustable and same in front.   only thing I haven't touched is the front lower control arm. Should I? what improvement can i expect ? I mean the one on the link below?   Car drives perfectly, it is just me thinking everything is either puly bush or hard bearing type so should also do lower control arm front but do I really need it ? https://www.japspeed.co.uk/product/suspension/adjustable-arms/nissan-200sx-s13-s14-s15-skyline-r32-r33-r34-adjustable-suspension-front-lower-control-arms/?gad_source=1&gclid=Cj0KCQiAo5u6BhDJARIsAAVoDWs5V_PauQPf0kx3zFCaA4tOC9Q7JSIsfJWma_jAPN2f1sJA686djOwaAidgEALw_wcB
