  • Replies 80
it will be fine for a P plater should still be enough grunt, just dont go braggin that ll beat every V8 commonwhore or Ford cause chances are youll get ripped. A normal ford or commie youll be good for
Besides that you will out handdle and out break them
Edited by race_snooze
it depends on the application. in your example, it should be good until you learn the basics of driving. (you might think you know how to drive now, but nothing compares to experience.) dont take that the wrong way.
haha yeah right, like it could keep up in any race with a GTR.
obviousely you never heard of Gunsai Togue (pronaunce kun-sai togae).
its Down hill race of twisty road, kinda catch the mouse game.
both running start from top of the top and one car must run away from 2nd car.
Non turbo AE86 won the race VS stock R34 GTR Vspec II
1.Power isnt eveything
2.one mistake it can be lethal
2cents
Edited by Pva_Glue
as above.. however i have a R34 25GT and i can beat the V6 calais by about 2 car lenghts but i can also keep up with stock GTS-T's (till about mid 3rd gear) lol
there is no way a r34 25gt will keep up with gts-t's unless it has huge cams, race port and polish and a hell of alot of nitrous!!! simple fact of torque and power. and that is coming from a guy that has driven both, and has been in one of the cars when they have raced.
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
