Associated Press (AP) 15 September 2005, 01:32 (Brisbane, Australia)
EARTHQUAKE ROCKS IPSWICH
A major earthquake measuring 7.8 on the Richter scale has hit Australia
in the early hours of this morning, with the epicentre believed to be in
the South Eastern City of Ipswich. Victims were seen wandering around
aimlessly muttering, "F'kin 'ell" and "Whadda baaarst'd".
The earthquake has completely decimated the area, leaving a damage bill
expected to exceed more than A$3000. Several priceless collections,
including mementos from the Torana Appreciation Society and the Ipswich
Progress Hall, were destroyed in the quake. Three areas of historic
burnt out cars were disturbed. Many locals were woken well before their
welfare cheques arrived.
Brisbane radio reported that hundreds of residents were confused and
bewildered, still trying to come to terms with the fact that something
interesting had happened in the area. One resident - Tracy Sharon Smith,
a 15-year-old mother of 4 said, "It was such a shock, my little
Chardonnay Mercedes came running into my bedroom crying. My youngest
two, Tyler-Morgan and Levi-Storm slept through it all. I was still
shaking when I was watching Jerry Springer later in the morning".
The people of Ipswich are a resilient community and evidence of a full
recovery can already been seen, with looting, muggings and car crime
carrying on as normal.
The aid response from local charities has been swift. The Red Cross has
so far managed to ship 4,000 cases each of Bundy & Coke and PJ Durries
to the area to help the stricken locals. Rescue workers are still
searching through the rubble and have found large quantities of personal
belongings,which include Centrelink booklets, Bronco tee shirts, Acca
Dacca
cassettes, Holden HSV bedding covers, Priceline jewellery and fine bone
china from Bi-Lo.
The Red Cross seeks to raise money for food and clothing, to be
air-dropped as parcels for those unfortunate to be caught up in this
disaster. Donations of clothing are in demand. Items most needed include
baseball caps; tracksuit tops (his and hers); flannelette shirts
(female); footy socks; ugg boots; and any other items usually sold in
"Op" Shops.
Food parcels may be harder to come by, but are needed all the same.
Required foodstuffs include, Pluto Pups (Dagwood Dogs), doner kebabs,
McDonalds, KFC, ice cream and cans of UDL Bourbon and Coke; Passion Pop
and XXXX Bitter.
Charities are also accepting cash donations through any Liquorland
outlet.
$0.25 buys a ball point pen for filling in compensation forms; $5.00
buys chips, sausages, gherkins, crisps and blue fizzy drinks for a
family of nine; $10.00 will buy a packet of Winfield Blues 25s and a
lighter to calm the nerves of those affected.
Aid agencies have requested that no tents be sent into the affected
suburb, as the sight of high socio-economic housing is unfair on the
residents of neighbouring areas.
Hope this is the right section of the forum for this.
https://www.sau.com.au/forums/topic/87873-disaster-in-ipswich/
OK.....I live in Ipswich, and I'll say something......
WELCOME TO 2003!!
This is soooo old and seems to go around every couple of months. So far I have seen Inala, Redfern, Woodridge and now Ipswich.
Some people have no originality.
I do admit though, the first incarnation I did find quite amusing.
There you go Sam :P
Edited by Lazy-Bastard
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
