Hi Gents,
Now that I have my shiney new Splitfire Coil Packs (Big Thanks to the guys at Kudos Motorsports) I need to fit them.
My current plugs are gapped at about 0.7-0.8mm.
What should I gap them too?
Would 1.0 - 1.1 be about right?
BASS OUT
https://www.sau.com.au/forums/topic/87888-plug-gaps-and-splitfires/
If its any interest to anyone, i've tested my std gtst old coils and the new splitfires, and aside from the primary winding resistance being .6 ohms against the stock ones .7 ohms, the secondary coil current is the same as the stock old ones(1.4ma). Also the spark gap they will jump is also the same.......(18mm)
This was using a set frequency coil tester, around 50 - 60 hz odd...... for 9000 rpm the freq would be 75 hz, so pretty close. stock coil might drop off abit at high freq, but i dont think its as much as they seem to indicate.
Anyone else done testing to argue otherwise ?
Gary
Gary
I don't even know what you're on about, how can I argue? :lol:
They only reason they "seem" much better is a lot of people buy those as opposed to ones off Nissan which probably is more expensive.
I dont think they are any different to stockers... its just that they are a cheaper brand new alternative
A Brand new coil pack is going to be better than one that is 5/10/15 years old
Yeah that was my asumption too, there just a blue version of a new coil basically...... there are minor diferences in the primary resistance, and also the core seems to be two E cores instead of all joined together. (ie the metal former is not joined on the sides)
I assumed this when buying them, but since there new and cheaper than nissan, there the ones to get.
I would think all the guys who report more power have old coils starting to break down internally , and worst case externally arcing onto the coil brackets.
Only way i'd believe these are better is run a car on brand new nissan ones till it was blowing the spark out at a certain gap, then swap these in.... but i doubt there would be any gain on new coils.
For interests sake i also tested the secondary current of some other coils .
gtst - 1.4ma
bosch mec 718 2.1ma
S4 rx7 trailing 2.9 ma !
Gary
Thats exactly what ive been thinking for along time ;)
my coils started arcing to the brackets (at least three of them) and as has been mentioned i bought the splitfires because they were cheaper than nissan ones. they look exactly the same, and i can tell you that there was definetly NO power increase when compared to my stock coils when they were working properly ;)
and talking gaps, with my splitfires i have run both coppers and iridiums with the standard 1.1 gap with no problem, but only at 10psi.
Wow I thought we were gettin extra juice outta these Splitfires.... Ripped off!! Just like thier friggin spark plugs..
well talking plugs, i swapped old (40,000kms 2.5year) iridium ix plugs which looked fine for new coppers, no difference. i only changed them because they were old...
i believe the standard coils in conjunction with being old somehow get damaged inside after being exposed to a lot of heat.
mine started arcing all of a sudden, within days after i went to a skidpan day(refer to picture ;) ), lots of sustained high revs, and it was a very hot day
I found a 10psi 1.1 mm gap was fine on irudiums
but
at 14psi it was blowing out spark.... If i reduce the gap to 0.8 then i get a small flat spot where there is too much fuel and its drowning the spark bsiclly.... So im gonna toss out the split fires and run after market coil packs and spark plug leads....
Should reduce the heat issues these things have also....
$600 for a set of split fires.....
vs.
$400 for a set of 3 double packs from bosch and $100 on a set of leads from autobarn....
Much the same price but i know which will do a better job....
Remember this one basic rule....
If you want more power you need...
1. More fuel (040 fuel pump and bigger injectors and maby a fpr)
2. More air (turn up the boost)
3. More ignightion (bigger plug gaps and more power for the spark)
If you dont increase each evenlly you will have trouble....
i got 3rwkw increase on back to back dyno runs just by changing to the splitfire coils, which im not claiming is reason to go out and buy em! my std ones were getting temperamental.
Plug gap had to remain at 0.7mm otherwise id get missfires at 1.2bar.
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
