Hi Gents,
Now that I have my shiney new Splitfire Coil Packs (Big Thanks to the guys at Kudos Motorsports) I need to fit them.
My current plugs are gapped at about 0.7-0.8mm.
What should I gap them too?
Would 1.0 - 1.1 be about right?
BASS OUT
https://www.sau.com.au/forums/topic/87888-plug-gaps-and-splitfires/
If its any interest to anyone, i've tested my std gtst old coils and the new splitfires, and aside from the primary winding resistance being .6 ohms against the stock ones .7 ohms, the secondary coil current is the same as the stock old ones(1.4ma). Also the spark gap they will jump is also the same.......(18mm)
This was using a set frequency coil tester, around 50 - 60 hz odd...... for 9000 rpm the freq would be 75 hz, so pretty close. stock coil might drop off abit at high freq, but i dont think its as much as they seem to indicate.
Anyone else done testing to argue otherwise ?
Gary
Gary
I don't even know what you're on about, how can I argue? :lol:
They only reason they "seem" much better is a lot of people buy those as opposed to ones off Nissan which probably is more expensive.
I dont think they are any different to stockers... its just that they are a cheaper brand new alternative
A Brand new coil pack is going to be better than one that is 5/10/15 years old
Yeah that was my asumption too, there just a blue version of a new coil basically...... there are minor diferences in the primary resistance, and also the core seems to be two E cores instead of all joined together. (ie the metal former is not joined on the sides)
I assumed this when buying them, but since there new and cheaper than nissan, there the ones to get.
I would think all the guys who report more power have old coils starting to break down internally , and worst case externally arcing onto the coil brackets.
Only way i'd believe these are better is run a car on brand new nissan ones till it was blowing the spark out at a certain gap, then swap these in.... but i doubt there would be any gain on new coils.
For interests sake i also tested the secondary current of some other coils .
gtst - 1.4ma
bosch mec 718 2.1ma
S4 rx7 trailing 2.9 ma !
Gary
Thats exactly what ive been thinking for along time ;)
my coils started arcing to the brackets (at least three of them) and as has been mentioned i bought the splitfires because they were cheaper than nissan ones. they look exactly the same, and i can tell you that there was definetly NO power increase when compared to my stock coils when they were working properly ;)
and talking gaps, with my splitfires i have run both coppers and iridiums with the standard 1.1 gap with no problem, but only at 10psi.
Wow I thought we were gettin extra juice outta these Splitfires.... Ripped off!! Just like thier friggin spark plugs..
well talking plugs, i swapped old (40,000kms 2.5year) iridium ix plugs which looked fine for new coppers, no difference. i only changed them because they were old...
i believe the standard coils in conjunction with being old somehow get damaged inside after being exposed to a lot of heat.
mine started arcing all of a sudden, within days after i went to a skidpan day(refer to picture ;) ), lots of sustained high revs, and it was a very hot day
I found a 10psi 1.1 mm gap was fine on irudiums
but
at 14psi it was blowing out spark.... If i reduce the gap to 0.8 then i get a small flat spot where there is too much fuel and its drowning the spark bsiclly.... So im gonna toss out the split fires and run after market coil packs and spark plug leads....
Should reduce the heat issues these things have also....
$600 for a set of split fires.....
vs.
$400 for a set of 3 double packs from bosch and $100 on a set of leads from autobarn....
Much the same price but i know which will do a better job....
Remember this one basic rule....
If you want more power you need...
1. More fuel (040 fuel pump and bigger injectors and maby a fpr)
2. More air (turn up the boost)
3. More ignightion (bigger plug gaps and more power for the spark)
If you dont increase each evenlly you will have trouble....
i got 3rwkw increase on back to back dyno runs just by changing to the splitfire coils, which im not claiming is reason to go out and buy em! my std ones were getting temperamental.
Plug gap had to remain at 0.7mm otherwise id get missfires at 1.2bar.
    • Update time!  The JZX110 had some maintenance needing to be done, so a lot of the seals with replaced to fix some oil leaks. Also used this opportunity to whack on a front mount that I'd bought some time ago.  I also finally got the rear lip painted and fitted.  I then got the exhaust done. It's just a catback for now. Custom made 3" stainless with a turn down. I could have a tip coming out, but it will require cutting the rear lip and possibly the bumper itself. So far I do like and it's made the car a little more zippy.  Close out with some nice pictures of the cars and a sneak peek of what's next.
    • Once you learn it all, you find you do the job once. But this is the best way to learn, as you won't forget the lessons
    • Edit: It's now known as "R Performance" and is still in operation.
    • This lady loved her FD for 25 years!  https://www.topspeed.com/80-year-old-woman-donates-fd-rx-7-mazda/ My brother in law. He's nice enough to let me drive it whenever. He'll likely not see this, but I'll try: @r-is-for-fun got any pics?
    • Just something I found searching for more info on Emotion R, apparently the ECR33 Skyline GTS25t was either originally black, or there were two of them, the black one being the original demo car, then building a white one which was part of the 1997-onwards (to at least 2008!) Cockpit Tatebayashi Tokyo Auto Salon booth demo cars. It appears that Emotion R closed down in 2008 and was declared bankrupt in 2010: http://bank-db.com/hasan/208365. Scan of a magazine with the black R33 from 1996: Wayback machine archived page from May, 2000: https://web.archive.org/web/20000529061027/http://www.emotion-r.co.jp/skyline.html Option magazine with a few photos from the Cockpit Tatebayashi booth at the Auto Salon from various years: 2002: http://www.jdm-option.com/photo/index.php?action=item&category_id=154&image_id=3507 2003: http://www.jdm-option.com/photo/index.php?action=item&category_id=137&image_id=3033 2005: http://www.jdm-option.com/photo/index.php?action=item&category_id=116&image_id=1831 In 2008 Cusco website mentions that the Cockpit Tatebayashi ECR33 was displayed at that year's Tokyo Auto Salon: https://www.cusco.co.jp/event/2008/12/post_735.html As of 2021 it appears that the ECR33 demo car ended up being exported to Florida, USA: https://rmcmiami.com/inventory/1996-nissan-skyline-r33-cockpit-tatebayashi-demo-car-big-te06-turbo-endless-brakes-lsd-450hp/ And finally here's Google streetview of the Emorion R garage in 2023 which is amazingly not only still there, but the showroom is still full of various parts in stock and funishings, etc.: https://maps.app.goo.gl/ttyEAZdZLyzermyT9 Apologies for nerding out a bit. I used to love doing this 20 years ago on SAU and got a bit nostalgic for a moment... 😅
