Ah theyre always good fun
GTR owners bitching about GTRs :)
Kind of reminds me a bit of the fast fours forums. Just kiddin guys !!!!
Damn, after tonight i can say 1.3 bar really hurts your chest :P
hey mate, so how much did u turn the ratio up to get a steady 1.3bar?
also last night the boost was most definetly turned UP not down, it must have been for some other reason (like wrxhoons car) that it was not running full boost... :P
  • Replies 288
also last night the boost was most definetly turned UP not down, it must have been for some other reason (like wrxhoons car) that it was not running  full boost... :D
Hey mate,
George was right about my gain being WAY too high.
I think my gain at the moment is about 15 or so. I played around with the ratio, while i had the gain set to 0 to determine the maximum boost it would hit. Once i got about 1.28-1.29 bar i stopped and then set the gain to about 15. It overboosts to about 1.32-1.33 bar, and settles on about 1.29-1.3 bar as intended :P
I think i will be at the drags again next week. Feels a LOT quicker. I was probably running no more than 1.2 bar that night, even on the quickest run ! But we will see :P
Mmmmmmmmmmmm drags :)
Hey mate,
I think my gain at the moment is about 15 or so. I played around with the ratio, while i had the gain set to 0 to determine the maximum boost it would hit. Once i got about 1.28-1.29 bar i stopped and then set the gain to about 15. It overboosts to about 1.32-1.33 bar, and settles on about 1.29-1.3 bar as intended :)
I think i will be at the drags again next week. Feels a LOT quicker. I was probably running no more than 1.2 bar that night, even on the quickest run ! But we will see :)
awesome, at least u got it sorted quickly!
do yourself a favour & buy a decent boost controller so that u can monitor your boost levels in every gear - this is the most important insurance for your powerplant
this reminds me of the days i had my vl turbo/exa turbo/datsun 1600...back then i would run a mechanical boost gauge with a bleed valve located under the dash - NUTS :)
Good question
I'm not actually sure anymore
Gut feeling says anywhere between 4600 and 4800
Reaches actuator pressure at around 4200 - 4400 i'd say
Will double check on saturday when i take it out on the freeway
well in that case u have the best controller on the market - dual solenoid is very stable
Marko
i have a dsbc spec R
While the recall button is cool, it only shows peak boost
yep! the club "spec R" is growing I am sure..... if only they could make the settings a little more user friendly!
marko and tommy when do you make 1 BAR? rpm?
I get 1 BAR at 2900rpm
I have a feeling both of you will make 1 BAR at similar RPM while the GTRS make more top end....
MUCH more top end... I smell 430kw marko :cheers:
Good question
WilliamsF1: considering this post, i'd assume actuator pressure is about 0.9-1bar? So sounds like tommy may be making 1Bar around 4,000rpm, not 3,000 like you?
What differnce does a 'built' engine make? forged pistons, upgraded oil pump and all that, thats more for saftey... I think most of the performance mods tommy and williamsf1 are on par, cams, turbos, inj etc... just different choices.
I doubt kebab makes 24 psi at 3k :D and I also doubt he makes 1 BAR at 3k .... he hasn't got cam yet (or should I say again )
but yes you are correct in the fact that DART built both of our engines, as is Marko as is Blitz... :)
but I would add that having a "built" motor does fark all for making more power in this case (setup I have) it just lets you sleep better at night knowing it was put together with some lovin'.....
Marko will make a shed load more power than all of us, but we are talking top end now, and that is a different game :P
TommyK will you give it a power run somewhere shortly for all of us to see? and did you notice much of a fix with the better boost control?
I'm guessing you ended up getting the Jim Berry clutch too? like???
Ben - power run is something i need to think about. I think im at the point where i dont want to spend any more money on this damn thing. But maybe i will be convinced to get a power run done at DART ? how much will they charge for a power run?
Boost controller only seems to fix spooling past 1 bar.
I ended up going for a different clutch. A nice little 9 puk ceramic that feels like stock, from UAS. Holds all the power i throw at it, and the girlfriend has no troubles driving it.
Tested mine to produce 0.5-0.6 bar ~ 7-9 psi @ 3300-3500 rpm in 3rd gear tonight. Not game to try 4th by any chance. not during double demerits! :P
Errrrr TommyK you own a GTR right ;) hmmmm = wife & 3 kids, or thats what my bank account shows I am supporting!
(and no I am in no way, shape, or form married with any rug rats!)
A power run at DART? I'm sure Jim would be more than willing to help you out there :P he is a top guy, and there are more than a few here to vouch for the work of the shop, all I say is drop in and say hi, all the guys are very clued up, and will be willing to have a chat :D
( 19 Belmore rd punchbowl )
the good thing about the dynolog is the acurate torque figure, and that is what really makes a fast car, not a nancy boy KW number :):)
.5 BAR at 3300? hmmm that does seem very low?
I know you have the SBC spec R, so how about setting the alarm on it to 1 BAR and then eyes on the road and the tacho gas it till it rings.... then you will be able to check your 1 BAR a little easier, and safer!!!
I wonder what PNBLGHT gets?
:P Heh, yeh tell me about it. GTR = way too much money. Yesterday i was at justjap trying to decide whether i should spend the $90 on a catch can, and i just couldnt bring myself to do it. Dont wanna spend anymore. My poor girlfriend gets nothing ;)
I will try and pop down to DART one day when i have time. Ben @ bel mentioned he would be happy to pop down and tune the car on the dyno for me :)
Ben - I'm pretty convinced i will not get spoolup any quicker. if you check out petes dyno graph (pnblight) you will notice that the turbos seem very laggy also
check his dyno graph out - makes very little power under 4k
I think these turbos are probably a bit mismatched. He has the cam gears etc. But bear in mind, these turbos are probably a fair bit bigger than the hks ss turbos. Places like GCG quote these turbos to be 350hp ? Because garrett still hasnt released any compressor or turbine maps, we still cant tell where the turbos are most efficient :D
Actually - just adding to that - GT2860R - 707160 - 7 is a lot smaller than the GT2860R - 707160 - 5 model. But they are both rated at 320hp. That cant be right. The - 7 is comparable in spec to the hks gt-ss and the -5 is comparable to the 2530. I think there is no point in comparing your SS's to my 'similar to 2530 spec' garrett turbos. Mine should make more power than yours seeing as they are bigger :)
Knowing what is the fastest possible boost build for the engine/turbo combination is very important. Otherwise I can't tell if the boost controller is doing its job properly ie, isn't leaking boost to the wastegate actuator before the target boost is reached.
What I do is a quick power run on the dyno with the vacuum hoses to the wastegate actuators removed. I limit the rpm climb so that the boost doesn't get too far past my target level. The logged boost curve is then the target for tuning the boost controller. It doesn't mattter what brand or style of boost controller, the fastest boost build possible is one achieved without any wategate opening.
If I am doing it without the dyno, I use a video camera pointed at the gauges. It's the poor man's data logger, just play it back in slow motion. The Datalogit works great as well, if you have one.
:D cheers :(
