So does anyone play texas holdem online and if so what sites do you guys play it on? theres a few like partypoker and tilt and things like that just trying to see if there are any good ones
i play no limit hold em on party poker...
my old man uses empire poker, which is exactly the same, just different appearance table wise etc...i like the look of party poker more
Which $1500 tourney was this? The Mahogany Room tourney was only $1000 and I played in 2 of them. Last 1 is this week but I didn't manage to get a seat in it :wacko:
he wanted to play in the crown tournament, but not lay out $1500 to enter
After trying to organise the last one, people all had better things to do on a Sunday then to come round and play. I'm organising a small one for a few mates soon to test run through some rules and regulations.
My playing area is small and I don't have my table felt yet but it's been ordered and should be here in the next couple weeks. If ppl are interested, come talk to me at the SAU meeting on Tues night so I can actually meet you.
Leewah what happened to the poker day/night you were organising ?
the brochure crown sent me said $1500...
abused go to crowcasino.com.au and then find ya way by the links to the poker part and it tells you about satilites and the sit and goes are only 1 table tments meaning you are only playing against the 10 ppl on your table not like the thursday night t'ment how there is multiple tables
does anyone else here play thursday night poker, went down tonight with 4 friends, 2 of them did really well, was an awesome night.
anyone that's never played in a real tournament before, highly recommend, only 75 buy-in, bout 250people, and top 30 places payed. makes for an awesome night out.
btw was anyone else there tonight (thursday)
hey guys
we currently play no limit wed nights, we have 7 players at the moment
30 minimum buyin... with no buyin limit
we are after 2-3 more poeple to make a full table. last wed the pot got to 1280
1st place gets all the money with 10% to the house for beer and stuff
any interest pm me
wat a combo fast cars and royal flushs
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
