well last night i cracked my block in cyclinder 3 right down the bore after making 688hp at the wheels without the NOS on not reved out, the block was a nismo N1 block which we just fitted in after cracking the std one, so looks like the nismo ones are not as strong after all, i was told today that u can get a stronger block called the group a block does anyone have any ideas where these can be bought from?
https://www.sau.com.au/forums/topic/88010-nismo-n1-block/
it was a std nismo n1 block, but we have weigh the std gtr33 block and the nismo one and there is no difference in weight thats why its got me wondered if there any different, the most i have made is just over 800hp in all four wheels and she was holding.
There is certainly a difference in price between the std (05U) and the N1(24U) blocks!
I thought that the N1 blocks had thicker wall castings (i.e. smaller water jacket galleries) - perhaps the additional metal is minimal in weight?
https://www.sau.com.au/forums/topic/88010-nismo-n1-block/#findComment-1589048
He has sourced things for the USA like 1990 300Z complete front ends made new buy Nissan and for me he has some 1987 Century badges coming and Toyota Japan are doing some new ones for us which delayed the bits by 3 weeks.
If Graham cant get the bit nobody can.
Edited by Guest
https://www.sau.com.au/forums/topic/88010-nismo-n1-block/#findComment-1591121
maybe on the new block if its drag race only grout fill it. On the a brand new rb30 we are building we are grout filling the block as well as running chomoly cylinder liners and a custom sump girdle, that lines the inside of the block and join the thin parts of the block to the girdle.
https://www.sau.com.au/forums/topic/88010-nismo-n1-block/#findComment-1592619
usally i make around 650hp without the NOS and this time when we where tuning it we played around with cam timing and found more power so it was going for 700 with out the NOS so maybe the nismo blocks arent as strong as everyone thinks they are. im only runing 87mm pistons so there not to big, i might have to look into cyl liners or the gt block which they claim its thicker again but double the price.
https://www.sau.com.au/forums/topic/88010-nismo-n1-block/#findComment-1595909
Just a question - the new N1 (or standard for that matter) blocks have an 86mm bore. Presumably retaining this bore size would improve strength?
https://www.sau.com.au/forums/topic/88010-nismo-n1-block/#findComment-1597651
a few things to clarify
NISMO DO NOT MAKE an N1 Block
NISSAN make the N1 block. It has a higher Nickel content than the Standard RB26 Block and is stronger.
NISMO just realeased their GT Block this year to co-incide(spelling??) with the release of the R34 GTR Z tune. It is the same block used in the GT500 Race Cars.
Gav, increasing the bore size helps you increase the displacement in the engine. Hence why the HKS 2.8L Kit uses 87mm Pistons.
Retaining the original bore size or only going to 86.5mm pistons aids in developing fantastic engine response (not something that is overly focused on in drag setups). Also going to an 87mm bore rasies concerns about the overall strength of the block. It's fine if you run a drag car that gets re-built often but for a street car that need to last, it's an unnecessary risk IMHO.
https://www.sau.com.au/forums/topic/88010-nismo-n1-block/#findComment-1604280
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
