Hey guys, a whirring noise has just started coming from the air con, sounds like a lawnmower in my dash. Well, maybe not that loud :P . Does this mean the a/c motor is on the way out, any ideas on how much it would cost to replace this, or does the whole a/c unit need to be replaced? I imagine it won't be cheap either way.
Cheers.
https://www.sau.com.au/forums/topic/8802-whirring-noise-from-ac/
i had the same problem, had paper (wtf!) caught in the fan, it was easy to get out though... (mine is a R33)
just remove the kick panel on the passenger side footwell left wall, remove the ECU, unscrew the 3 screws holding the black cylinder looking thing up into the dashboard, and gently pull it out, it houses the fan.. clear it out and stick it all back in :D 10 minute job, and i put of with the crappy noise for months!
good luck!
does your aircon work popperly? producing cold and so on.
could be the a/c compressor that is getting weared out. so remove the belts to get to a/c compressor belt and remove it too.
then turn it by hand it should turn smoothly with out any odd sound and you should also press and pull on the pulley in all directions, you are looking for clonks and wiggling. if there are any your compressor needs to be changed
matt, got the same prob. its quiet when cold, if i got it on for longer then 15 mins, starts whinning like a bitch. still cools the bastard though. dunno if its the same prob exactly as mine, but my compressors ****ed, maybe yours is too.
yep, sounds exactly like what mine has been doing, on really hot days it would struggle to keep the car cool though and i have to turn it off after a while and back on again and it starts cooling.THis was happening for about two weeks and on friday it blew up!! It started blowing hot air, then there was a burning smell and a bit of smoke from under the bonnet, I turned off and the smoke and shit went away. So now I'm without air con and it's really ****en hot. Hope this can be fixed easily. Hope yours doesn't blow up!!
i got the shits with mine and bought a second hand compressor anyway. cost me $200 but its worth it. didnt have a chance to fit it though, front brakes locked up at 100km/h and i hit a parked car, but hey, atleast now that i got the motor out, makes the compressor swap easy :P
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: wrxhoon@yahoo.com I'm not on this forum much .
