Used RAYS TE37
- 17x7.5" +29
- 17x9.0" +28
- 5 Studs PCD 114.3
- 2-3 tyres need replacement
- $2,199.00 pick up in Mel
- Some scrathes on this rim
Edited by BT-Revolution
  • 3 weeks later...
  • 2 months later...
  • 1 month later...
sending PM :-)
Will these offset fit a ER34 GTT Skyline? I know the originals are 17x7.5? but not sure of the offset. Anyone know the correct offset for R34 GTT? I really like this wheel TE37 but unsure if they will fit. Does the TE37 somes in different offset?
