hi, I want to import a EVO 7 from NZ to sydney. Would someone be able to tell me all the costs involved like compliance and taxes and about how much they would be.
Also the procedure of importing and any other tips would be very helpful.
Thank you very much
Its a 2001 factory standard Evo 7, the only mod is 17 inch volk racing alloys.
https://www.sau.com.au/forums/topic/88036-need-help-importing-evo-7/
  • 3 weeks later...
as far as i know, it's the same as doing it from japan.
go to www.j-spec.com.au or www.prestigemotorsport.com.au -
both have import calculators. Instread of the yen FOB price, just use the cost of the car at the moment in AUD.
budget roughly $4000 for Evo compliance? not 100% on that.
will need a set of factory rims i think too. Add that to the cost.
some of the evo compliance varys i think from $5000-$7000
not sure on current costs if its came down.
The new sevs stuff can be very tricky tho. you WILL need to remove teh alloys any exhuast etc. car has to be STOCK STOCK STOCK.
ive heard of a few evos being sent back......
mick
Evo 7 private compliance is $5,500 + GST + tyres @ CROSSOVER CAR CONVERSIONS, FERNTREE GULLY, VIC.
or
$4,750 + GST+ tyres @ RECREATIONAL VEHICLES PTY LTD, NERANG, QLD.
* Rec Vehicles said that they would charge an additional $2k for new cat and brake pads if the car had done >= 80,000km.
It's possible to get a grade 4 with 60-70 on the road in QLD for $30k, provided the pads don't need replacing. They seem to be coming down and 1 AUD = 86 YEN atm. I'm just not sure that the build quality is as good as Nissan or Subaru.
http://auctions.amayama.com/mitsubishi/lancer/
  • 1 month later...
for a good EVO7, you are looking around $40k+ on road.
but since you own the car in NZ, if you are the australian citizen, do it as  a private import, if not, get the cash ready. looking around 10K for everything up. that include shipping, compliance, and rego.
Is importing a car from NZ more cost efficient?
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
