hey all,
currently looking to purchase a new intercooler for my r32. just wanted some feedback...
what is the difference between a tube-fin compared to a bar-plate cooler. what will be the better buy and what would be the prefred intercooler choice - keeping in mind performance etc.
thanks
https://www.sau.com.au/forums/topic/88052-intercooler-question/
well tube - fin intercoolers are more free flowing and u will hit boost alot quicker than a bar and plate. but if u goin for big HP i Recommend that u go for bar - plate coolers coz they are made for more cooling than tube - fin.
otherwords if u got a big aftermarket turbo get a bar -plate cooler
if u just want more boost get a tube - fin, boost will come alot quicker
hey all,
thanks
no matter what way you go, you'll get turbo lag...thats the way RB20's are with big front mounts thanks to the plenum chamber going across the top of the engine :blink:
i've got a tube fin cooler from modyourcar.com (600x300x76) - it cost me $400 and then got a mate to fit it for me. And that's your biggest cost, the plumbing is a big job and if you don't know a mate than can, or if you can do it yourself, it will get costly if you go through a workshop. The upside is of course the performance and cooling benefits, but also, with the factory cooler out, it makes a nice little cold air box in the space left behind! (see pic)
Couldn't tell you too much about performance differences but don't get too hung up on what type of cooler to choose, for the performance gains you'll get, save the cash for other stuff (ie injectors, fuel pump, FPR, power fc etc etc)
no matter what way you go, you'll get turbo lag...thats the way RB20's are with big front mounts thanks to the plenum chamber going across the top of the engine :P
rednut do you have any problems with the air intake being that low when it rains at all???
What routing did you do your piping, the bacj and under, or over top?
Cheers B
    • 1. Factory knock sensors for now, honestly the RB26 OEM knock sensors seem ok as they're flat response instead of resonant type but they appear to be internally grounded to the block. If I do replace the sensor it would just be to get ones that are not internally grounded so a differential input can be used to reject common mode noise. Definitely plan on fixing this as a part of the tuning process. 2. Never deliberately induced knock, though I guess I could try that experiment if I really wanted to. 3. All of this is basically on a stock engine + ECU, only modification is HKS GTIII-SS turbos and a Nismo plenum. Currently I run it with the wastegate solenoid unplugged so it won't try to raise boost past wastegate pressure.
    • After being peer-pressured into paying $100 for the MW remakes, got BO6 on XBox Game Pass. I think that's worth it.
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
