Unfortunately its not the way it is.
Note all the ppls that have gone to a pfc and gone. 'wow' the extra mid range power.
I would kill to have a good look at a rb20det or rb25det stock ecu's ignition map.
Alright let just say everything else is the same (engine, mods, drivers,...) and you put 2 cars agaisnt each other, one SAFC and the other PFC, which one would win on 1/4 mile?
This do? rb20det.. I've got a couple of people that I need knocked off, let me know when you're available :P
Ok - look at this graph I ripped from the stagea section. THis guy used the SAFC style device to tune (A jaycar version) - he was able to get good AFR the whole way. If you were using PFC you wouldn't get that much better AFR control and the only real other thing governing power is the Ignition timing which I would imagine is close to as far advanced as you would want....
Where could PFC benefit you here then???
As you lower the afm signal to lean out the car it runs more ignition timing. Not good for a reliable motor you want to zip around the local track or on a 30-40degree day.
The dyno graph you posted I think is a bad example.
Look at that nasty arsed power dip smack in the middle. :D
I guess the bottom line is about the money, how much u wanna spend on mods. Obviously if you can afford PFC then it would definitely be worth it. However for those are on a budget and not after massive power, a SAFC give excellent value for money, plus that fancy blue LCD to impress da chics :D
Ben, sure the SAFC can provide a straight AFR curve/line throughout the whole rev-range but I haven't noticed anyone here stating how 12 points of adjustment (SAFC) is alot less compared to the 20x20 map of PFC.
With the 20x20 map, usually TPS vs. RPM, you have much MUCH more potential in tuning the car. This doesn't mean the car will only go good on WOT but you'll also have control over cruise conditions, slightly accelerating etc.
But in regards to mods, mild mods such as boost, full exhaust, IC, CAI - SAFC/E-Manage will be a more suitable choice, although there should still be much to gain if you do go PFC.
Ben1981
You can't advance the ignition timing with a SAFC.
Ignition timing is where the power is.
I went from 165 rwkw to 200 rwkw with a powerFC and made much much much more power EVERYWHERE.
Including right at the bottom.
Even if the powerFC costs $1000 compared to $400 for the SAFC, the value for money is still more better with the PFC.
Oh, and to think that you will only ever need the SAFC cos you aren't going to mod you car any further..... Well, that's just silly talk :)
I once thought that, and now I'm chasing 260 rwkw with my next mod.
Stoopid Cars.
If you are on the boarderline of detonation and at 12:1 AFR for the whole rev band then you won't gain by having a PFC.
Apart from the fact that you have a signifigantly larger amount of load points :O
PFC tune and get a great result as opposed to a reasonable one (saf-c)
Look at that nasty arsed power dip smack in the middle. :)
indeed :)
True it is a compromise - but that dip in the power curve mightn't be fixed by PFC either.
Umm, its the mid-range dip that everyone has come across.
Search around for dyno graphs and you'll find lots with the "dip"
It will definately be fixed via PFC
ok ok. Maybe the PFC is a lot better but I think with minimal mods it may be a bit of overkill, up to the individual.
I really don’t think my car needs to be much faster for the street though. I reckon with the SAFC or DFA I will manage about a 13.8sec quarter. About as quick as a boxster right?
With a bit of boost, stock everything other than exhaust, I made a 13.4 quarter.
But, I had a slightly slipping clutch (only on launch) and a fully prepped track launching me to a 1.9 60ft.
Exactly the reason why I chose the E-Manage over the SAFC or PFC. Much more control than SAFC (16x16 for both AFM and Ignition compared to 12rpm points) and a hell lot cheaper (1/3 the price and about 1/2 price in tuning) than a PFC for a GTiR.
The E-Manage is what I consider just "perfect" for my car with "mild mods": Stock turbo with bit of boost, full turbo back exhaust, Pod with CAI and box, fuel pump, FPR.
Fair enough - I can certainly feel the stock ECU playing games around this RPM, hoping to tune it out with the DFA. Would be good to drive a SAFC tuned car and a powerfc cars with equal mods to see the actual difference. I know people here seem to say they are streets apart...
    • Um.... This is not easy. I will have a fiddle with it, but make no promises. I think, given the explicit resistances vs temperature, and your ECU measured voltages, it should be possible to match them up. I will do that by assuming a 5V supply from ECU to sensor, find out how much current would have to flow to produce that voltage, then use that current as a .... nah f**k. That won't work. The supply voltage is fixed, but there's nothing to say that the ECU regulates the current too. Um... I dunno. I guess there's a voltage divider setup in the ECU. As in, there's another resistance between the ECU's sense terminal and ground. That way, as the sensor resistance changes, that's how they get a floating voltage that varies with the temperature, without having to control the current. Give me a minute or 3.
    • *that* is a question for chatgpt (or someone that understands maths....but I'd try chatty). Drop them the table and ask for the formula
    • Alright. Exhaust has been looked at, and booked in 'soon'. I'm not 100% convinced it's going to be as good as possible but I'm going to go with it anyway. If I get a reasonable thing that works for 10 years I mean that's twice as long as I've lived with the current one. I have a more pressing issue. I have fixed my MPVI3 (by buying a new one). Excellently, one can wire in analog 0-5v inputs to the ECU itself. I had wideband already via Serial so I also wired it in via the direct input. The idea being I can use the standalone logging without a laptop and have Wideband data in it. The other wire I thought I'd use oil temp. This is where I've gone crazy. HPTuners requires you to implement a formula so you know how much volts = how much temp. This seems relatively simple to me. However I cannot find the scale for this anywhere on the internet, nor decipher how to figure it out without removing the sensor from the car. All I know is that voltage actually goes up as temperature goes down. I am using the actual gauge, so I can see what the temp is. The signal wire has been branched off into the MPVI3. EXAMPLE: 2.68v = 58C 2.7 = 57C 2.74v = 56C 2.8V = 54C 3.06V = 49C 3.18V = 47C 3.37V = 43C I think the gauge is 50-150C. It may be more. It may be less, because I can't find it for the love of f**k. It appears all the information about the gauges I have has been scoured from the internet, but the sender is VDO 320.021 I believe the resistance chart is this How the f**k do I convert this to a voltage? Once I have a voltage... I then have to perform this transform of said voltage to show it in the scanner: https://www.hptuners.com/help/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm @GTSBoy you're probably my only hope here TEST YOUR MIGHT
    • Here’s the updated and installed muse replica nismo ones … very happy with the outcome. Eventhough I painted my whole rear end due to my rich idle lol.
    • Hmm. I had a good look (w/o searching, because I'm not logging in) and couldn't see it either. I distinctly recall the thread, not many weeks ago. It must have been removed or perhaps put into the back section. If it was in Off Topic you should at least have been able to search it up. So if I'm not hallucinating, it is fairly decently removed.
