hey guys/girls
im doing a timing belt change on my r32 gtr next week and was wondering if the water pump should be done aswell,as ive been told by a few people i should?also if i di should i get an n1 water pump or just a standard r32 gtr one? also where would be the best place to gwt one from???
cheers kane
https://www.sau.com.au/forums/topic/88091-water-pump/
sit inline. they're electric so they claim a few extra hp cos its not being driven off the crank. about 300ish from memory. not too sure because it was fitted when i purchased the car.
they have since released an electronic controller that can control the speed of the pump to keep temps at the ideal range and can be set to "run on" after ignition off to keep water circulating through the engine to help it cool down.
do a search dude!
d
https://www.sau.com.au/forums/topic/88091-water-pump/#findComment-1591609
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
