Guys,
My L20et is not happy off boost. When cruising on partial throttle, it is very sluggish when I give it a little more throttle. Once full boost is reached it goes fine. Also when cruising, it will some times stutter for a short period. It never breaks down or stops the car, but it does seem to be getting worse. I have changed leads, so I don't think they are the problem. I suspect it could be something to do with the throttle position sensor or oxygen sensor. Does the engine run closed loop operation at cruise and open loop at wide open throttle? Any ideas what could be going on? Its standard apart from RB20DET turbo and small front mount intercooler.
Cheers,
machg
https://www.sau.com.au/forums/topic/88117-l20et-sluggish-off-boost/
It's only got 7.5 C/R!
Engine only runs closed loop under cruise conditions. As soon as you start moving the throttle off cruise, the ECU should start ignoring the O2 sensor signals.
Is the distributor in A-1 condition? Does the vacuum advance work properly?
7:3.1 to be on the point. Now mine has quite a bit down low. i can drive it happly off boost and not hold anyone up. As i said before. advance the timing to 20btc or 22. The o2 sensor seems to bog my car down alot, and its a brand new sensor. so i dont use it apart for running my A/f guage.
The l20et does get anough fuel to be able to advance the timing, factory seting is 10btc, which is poor. Also the l20et injection system doesnt use vacume advance/retard. Its all electronic optical sensors
Guys,
Cheers,
machg
YOu state boggin down ect. id also cleen all your ecu plugs and component sensors. I also had similar problems when my TPS was fu<ked.
Crack open your afm and cleen the slider and tighten the afm 3 teath.
Cheers,
I'll try checking and cleaning some more.
machg
I advanced my timing to 20 a few days ago, motor stalled when gas was just tapped and was very very sluggish off the mark compared to usual. I've put it down to 16 and all seems to be better now.
DO you reckon the O2 sensor should be unplugged? I still need to clean all of my ECU components aswell (havnt done it since i got the car). I played with the screw on the AFM a while ago. How do I know when its set to a good position? I assume i need a Air/Fuel Ratio Gauge or a engine analyzer?
trying the o2 sensor is a test. i find my car is dog as slow and boggy with it pluged in. Cold start is horrid also... Without it. Ive gained heaps of torque and its smooth as from low down right to redline.
The screew on the afm is only the idle air/fuel mixture. Pretty much lets a small about bypass the afm so you can tune your idle. It doesnt do anything to your normal running rpm a/f
Haven't had a chance to clean/play yet. Will the Skyline ping if I advance the timing? (I'm in Tassie and we only get shit for fuel down here {95 RON})
machg
i dobut it will ping. Ive neaver heard mine ping. Just do go to hard out on advance and you will be fine.
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
    • If it does get a turbo it would blow the JCW Mini out of the water considering how "close" some of the tests were. Then again the Mini would probably get one of them Stage 69 tunes.
    • Next up, the extinguisher is mounted but really only temporary because I ran into clearance problems (the bracket fit fine....until I put an extinguisher on it). It picks up the seat bolt mounts but has long bolts running through 20mm spacers for now Doing it properly requires a bit of quick welding but I ran out of time, this will do for the practice day
    • Family events weekend but a snuck a couple of things in. NSW state champs were down at Wakefield so I got Gordon Leven's to bring some A052s down in the right size for some spare rims I had that "fit" (actually ex-Leaf Nismo.Rays in 18x7.5). Tyres are 235/45/18 so they are narrower than stock (19x8.5s) but I need to keep road tyres on it for daily use for now. In a first, those weird size tyres had been in the yoko warehouse for so long (4.5 years apparently) that they offered 4 for the price of 2....so 4 practice tyres for about $1100. Bit of a bargain for sticker tyres, considering the real purpose of the practice day is mostly to see how the various temps go (and the weather is due to help, forecast 32o). In terms of race wheels, it looks like I should be able to fit 9.5 fronts and 10.5 rears but 18 vs 19 height will be based on what tyres I can get in the right size - good tyres are very limited in available widths in diameters above 17" so some planning is needed. Once I'm sure this car will work I'll order a set of custom BC wheels like I did for the R32, you can get exactly the right width and offset to make the most of the available space in the wheel well (the 32 has 295s all round on 18x10s and they are awesome) Incidentally A052 are asymmetrical but not directional which is good news for rally use if the front and rear wheel sizes are different because I can swap them side to side on the same axle. Directional tyres are a nightmare with staggered size wheels because each tyre is fixed on that corner unless you can get it rotated on the rim (not really practical mid rally in most cases)
