  • Replies 55
I bought a R32 because they are less common than the R33s, and provide good bang for your buck. I love the shape, but now that we sold it, i don't know if i'd buy another one, unless it was a 32 GTR. Im actually kind of interested in a R33, as they have a better base for big HP, and are generally in cleaner condition due to age...
https://www.sau.com.au/forums/topic/8813-r32-vs-r33/#findComment-129881
If we are talking GTR's then the 32 is better, less weight and a real race car.
If we are talking GTS-t's then the 33, better looks, engine and newer.
All skyline owners have a good thing, and I like all the cars, but some are better than others.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8813-r32-vs-r33/#findComment-129892
looks are personal prefference.
myself, 32 looks a shitload better than the 33's, alot more aggressive in its styling.. 33 was when rounded cars were coming into fashion. ergh.
but both are awesome, 33 is obviously newer, larger engine capacity.. i had to go for the 32 even though it was more expensive, (mods+condition) because
A> looks
B> you dont see any on the roads, you'd be lucky to have more than 20 in perth. there's more R's than T's.
Shaun
https://www.sau.com.au/forums/topic/8813-r32-vs-r33/#findComment-129908
The RB20DET starts to have trouble with lag as soon as you want 200+rwkw.
RB25DET is a much better base for power.
BUT.. I do like the R32 Interior a little better as personally I don't like the dash in the R33's or R34's. They seem a little plain, especially around the glove compartment.
If you don't want to run any quicker than a high 13 or around 190rwkw then a R32 is quick.
Exhaust, FMIC, Boost & a bit of timing she will be quicker than a R8 255LS1 Maloo Manual Ute. Well mine is I found out the other night.
When I say quicker I don't mean just beat him i mean pulling away through every speed and rev range.
RB25DET Turbo and boost to 16psi with a ECU remap will see around MAYBE 190rwkw most probably 180rwkw, honestly i don't know but its some where around there.
180rwkw is required in a R32 to out accelerate a 300kw GTS on a rolling run.
Which for the average joe is plenty.
https://www.sau.com.au/forums/topic/8813-r32-vs-r33/#findComment-130046
like most ppl who opted for a 32 i do so cause i dont like the R33s awkward shape in stock form... i mean the high back end and low thin front. lines dont flow and its round and bulbous which is why they styled the R34 more on the R32... line flow right thru to the rear and is squarer not rounded.
200rwkw is probably more than i would go to at this point, i would be happy with about 170 or 180... ppl who say they buy the 33s over 32s cause they are newer really crack me.... the whole newer is better thing... even ppl who buy 93 model R33s say this lol on that sort of comment one would think that a 1969 mustang is worse than a 1980s mustang... comes down to preference, age is just something for those that are paranoid and wear nike cause its in fashion.
IMO
https://www.sau.com.au/forums/topic/8813-r32-vs-r33/#findComment-130532
Originally posted by tlai909
0.9 bar a lot for a stock turbo. I run 0.8 and I should turn it down on hot days as soon as I CBF using the EBC.
T.
if u have a good fmic your turbo will actually be running at 0.9 bar when u set the bleed, ebc cause with the stock cooler, especially on a hot day u get a huge pressure drop from turbo to intake so the tubo is actually running more then 0.9 bar at times to get 0.9 bar at intake.
and just to prove it i got 165kw@wheels at 0.5 bar when previously i was getting 155kw@wheels at 0.8 with stock cooler!
https://www.sau.com.au/forums/topic/8813-r32-vs-r33/#findComment-130541
ahh ok so obviously the hotter the air the more space it occupies.
Hence pressure drop.
So when it is cooled from the FMIC the temperature change is greater compared to a cooler day.
So the air after the FMIC on a hotter day will be occupying a smaller area compared to that same charge on a cooler day.
Did i kind of make sense.
That is why with a bleeder you get less boost on warmer days compared to more boost when the air is cold and chilled.
Cool air can only be cooled so much I guess where as with the hotter air the heat exchange is better hence more effiecient.
I think thats what i was trying to say .. :D
Inasnt.. For some reason I've seen so many R33's make much more power once fitted with a FMIC and running the same boost.
With the R32's for some reason they stay around the same power maybe pick up a rwkw or two but nothing like 10 or 15rwkw like the R33's on the same boost.
Could this possibly due to the ecu pulling timing out with the R33's in turn reducing power where as the R32's maybe the ecu isn't as aggressive or the CR causes less pinging?!?!
Any 1?
https://www.sau.com.au/forums/topic/8813-r32-vs-r33/#findComment-130553
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
