Joel,
The R33 ECU is much smarter with the addition of the MAP sensor. Not only does the MAF sensor measure air volume, the MAP sensor then figures out how compressed this air is. So it adjusts it's timing to suit. An After market ECU like a Microtech can easily prove this as it removes the MAFS and adds a tempreture sensor to the intake pipe for more accurate numbers after the FMIC. Much more power. After programming R32 ECU's there is really not much to them in terms of variable input parameters, but they are much more flexible and fun to toy with.
https://www.sau.com.au/forums/topic/8813-r32-vs-r33/page/3/#findComment-133825
  • Replies 55
And Vise Versa, The Z32 Airflow meter plugs into the r32 ECU with a slight wire change and with a simple re-program of the EPROM, your way. I think from memory, upgrading the R33 ECU requires a daughter board which I think is expensive. So I think an ECU change would be on the cards. But don't get me wrong, the stock ECU works well some fine bolt on mods, FPR, SAFC etc. I still prefer the 33 because it has more balls low down in the rev range but it is cumbasin. But I do like the sudden rush when the 32 comes on boost and it's agile.
https://www.sau.com.au/forums/topic/8813-r32-vs-r33/page/3/#findComment-133878
There was a bloke on SDU that only showed his face briefly stating that he reprograms the Z32 ECU to suit the R33.
It requires no modications. Apparently you can also use the R32 ECU in the R33 but you have to make a circuit to turn on the VCT at a certian rev range.
remember 'APPARENTLY'
https://www.sau.com.au/forums/topic/8813-r32-vs-r33/page/3/#findComment-133923
theres more r33's in sydney then excels these days. cubes dont always make a car quicker or better, and to tell you the truth, the only thing the 33 has against the 32 is the cubes. you can sit around all day saying 33's are better coz they got the 2.5, but seriously, they feel like they are 2.5 tonnes heavier too! personal preference, 32, easier to drift, parts easier to come by, and if your upset about cubes buy a RB26! if cubes make a car quicker, why havnt we all got RB30's in our skylines?? or better still, if cubes make a car quicker, why dont we all drive heavy pushrod V8's lol.
https://www.sau.com.au/forums/topic/8813-r32-vs-r33/page/3/#findComment-140113
The RB25 is a better motor all round. Better flowing head, VCT etc.
RB30.. I'd like one.
Mild 250rwkw, 9:1 or 9.5:1 CR with full boost by at least 3000rpm.
Cubes also allow power to be more controllable.
RB25 making 200rwkw compared to a RB20 making 200rwkw.
The RB20 is going to take longer to get there and when it does it will go from almost nothing to everything. RB25 will be more progressive. RB30 even more so.
Its all about drivability. :)
I don't like having to chase.
https://www.sau.com.au/forums/topic/8813-r32-vs-r33/page/3/#findComment-141545
Cars as a whole, have to be seen as a luxury, it's very hard to actually make money on a car........... similar to women!
but if you're looking at resale, 32's are the way to go NOW.
As most of you may know, as of May 2003 R32's can no longer be imported to Aus..... Period!........ so on a collectors side of things they will become rare and unless someone wants to buy one already Aus registered and thrashed like most of them are, Now is the time......
and yes...... definatley get out of shape alot better for driftin!
https://www.sau.com.au/forums/topic/8813-r32-vs-r33/page/3/#findComment-141871
I love R32's!!! R33 just happened to come out at the time they gave cars severely rounded shapes which gave them a strange look on some viewing angles(GTR still looks good though), but they got it right in the R34 when they styled it off the R32 style.
R32 GTR/GTS-4's are also easier to switch between 4wd to Rwd than R33 and R34!!
MEGA
https://www.sau.com.au/forums/topic/8813-r32-vs-r33/page/3/#findComment-141912
I love the fat look of an r33 rather than the slender look of a 32. Dont know why. Especially when you slap some degree of bar on them, wether it be the 400R or the GTR bar, they piss all over the 32 looks wise.
32 doesn't responde as well to body mods either.
also in my experience the 33 has responded better to first round of mods ie. Filter, cooler, boost up.
What are the torque differences between the two cars in relatively stock trim? 33 seems more seat of your pants quick.
https://www.sau.com.au/forums/topic/8813-r32-vs-r33/page/3/#findComment-144659
a friend had a 32 gts4 and my 32 gstt > we both running stock > on rolling I was leaving him by a couple of cars. On standstill he had me till I hit 3rd gear then it was me ahead again
I say put a 2.5 in the 32 and the 32 will be the pretty hard to beat even if the engine was stock
https://www.sau.com.au/forums/topic/8813-r32-vs-r33/page/3/#findComment-145140
The standard looking R33 i don't think looks much chop but with the kit on, its quite a good looking car imo.
For a gts-t i'd prefer an r33 (like i have) but if i wanted a gtr for some reason i'd go for the R32 version compared to the R33 version. I guess its the less weight thats appealing, and the GT-R with the kit and some visual mods can look very good
Of course R34 GT-R is the ultimate but we're not comparing them. Still, give it a few years, and they'll be down to R33 prices and the "last of the RB skyline" could be equally as collectable as the R32 GT-R. Then i can maybe buy one :rolleyes:
https://www.sau.com.au/forums/topic/8813-r32-vs-r33/page/3/#findComment-146071
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
