Does that mean we have to go out and source one ?
SK : Any ideas where I can easily obtain one and how much except a wrecker...
Try the "For Sale" and "Wanted" forums, then it's import dismantler time.
:wave: cheers :wave:
  • Replies 322
Posted Images
My workshop actually had two front ones lying around, and I had to source the rears from a wrecker. Tracked them down within 24 hrs. These are readily available with so many people pulling the stock suspension out and putting coilovers in. I'm not 100% sure but I think R33 caps fit, so you shouldn't have too much of a problem...
Ok sorry if I sound confused :P
Can I use the ones already on my car, yes they are stock.
  • 4 weeks later...
Mine say R33 GTR for rears and R33 for fronts.
I ordered for R34 GTT.
Is this ok ?
Yes
The R34GTT has the fork style on the shock bottom, so we have to use the R33GTR shock body.
Front is the normal eye, so we use the R33GTST shock body.
:O cheers :laugh:
Edited by Sydneykid
  • 1 month later...
There area limited number of rear Bilsteins in stock, so move quickly or you will miss out. No production planned at Bilstein Germany until after Xmas.
:dry: cheers :D
Are the fronts still avaliable Gary? :) Interested in whole set front and rear. I'm talking about the shocks. :no:
Yep, both front and rear shocks are currently available. PM me for details
:) cheers :)
  • 1 month later...
buy some special SK bilstein shocks ppl's... you know you want to...
:D
swaybars would be the whiteline items if i'm not mistaken, check the first page for part numbers.
Just a note that I have the Whiteline springs from this group buy for sale if anyone wants them. They are brand new and have only been taken out of the box to been have a look at.
I'm after $250 plus postage so if you're after a set of springs PM me and save some dollars. :D Hope you don't mind Gary. :D
  • 3 weeks later...
hey sydneykid. i just saved up enough to get after market suspension and have heard what u got here is one of the best.
i dont know exactly what i need i was wondering if u could help us out.
PM sent
:laugh: cheers :P
Hey, can you tell me where I can find your suspension settings? Have seen them before but can't remember where.
Thanks Wogboy
Page 1 of this thread.
;) cheers :huh:
  • 1 month later...
Sorry guys I have been on holidays since the 20/12, I will get around to the hundred or so PM's over the next few days.
I don't have definite delivery date for the Bilstein shocks, but they have been produced by Bilstein Germany, so it is only shipping time. As soon as I have a confirmed date I will post it here.
All other items for R34GTT's are available.
:) cheers :(
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
