  • Replies 322
Posted Images
hi, I need urgent help. I am fitting my front coilovers and sway bar - how the heck do you fit the sway bar. I have undone the little moving eye socket thing near the brakes, and have undone the rear nut on the bracket holding the bar to the chassis - but the front nut is obscured by part of the suspension assembly - do you have to remove this part to get to the nut? It looks like a bugger to get off - and even worse to get back on! Please respond asap.
Got my kit installed on Friday. Excellent products! Top service from Sydneykid!
Just want to confirm something with other GTT owners. After install Bilsterin shocks on the lowest setting (3 circlips down or all the way down) with factory springs on all four corners, the front end of the car looks lower than the rear. Measuring by eye there are narrower gaps between the front wheels and guards than rears. Is this normal? I though factory GTT is lower at the rear?
Cheers
^ I thought a lot of cars, the rear guards just have bigger gaps than the front? so you could lower your car evenly all around, but the back still "looks" higher", but it's just the guard is cut a bit higher? Dunno, that's just what i thought...
before i PM SK, just wondering for those that have received goods, roughly how long did it take after you paid?
cheers,
daniel
Hey Daniel,
My Bilstein shocks arrived within 5 working days of placing the order. Sway bars took a little longer coz whiteline had to make them fresh, received 2 weeks later. Best thing about this group buy is SK always keeps you updated and very prompt with pm replies.
Cheers
i think SK is a little swamped with something at the moment. It's been 2 weeks since i've paid, so i'll give it a little longer and then PM to find out the g-o... don't want to hassle :P
so how you finding the car??? Have you got the FULL kit? the rear spoiler giving you have extra down force yet?? :/
He was active the the last few days. I sent him a pm and it went through so it wont be long till he contacts you.
I didnt get the full kit just Bilsteins in stock springs and a couple of sway bars. Simple mods but transformed the handling enormously. Car feel more planted to the road, minimal body roll on corners and the ride is as comfy as factory. so far so good. Will find out more when I take it to the track.
As for the rear spoiler Im just wait for my side skirts to arrive so I can get everything painted and fitted. And hopefully the GTR wing would give me extra down force above 180km/h.lol :cool:
Which components did you order?
just adj. sway bars at the moment. Didn't realise that getting the bilsteins with stock springs was an option?? i would thought you get them with the whiteline springs, or not get them at all.... interesting.
having this FULL kit is very high priority on my modifying list, but don't really have the cash to do all in one hit. But am keen doing it little by little, looks like the bilsteins may be next :) Becuase i know i can't do the "i want lower springs" without shocks
so SK recommended this option, sway bars and shocks? or was it something you specifically wanted to go for?
Me thinks SK would suggest the whole kit. Thats what he designed it for. Every setting should be as he described. But if you cant afford it....
Go the swaybars first, then shocks, then springs, then bushes/adjusters.
If you could afford the whole kit it would obviously be the best option.
The reason I got bilstein shocks only is because I dont want to lower the car too much but I do want improved handling as well as factory like ride comfort. These bilsteins have built-in adjustable circlips which in the lowest setting they could lower the car by 24mm in combination with factory springs. and thats plenty lowering for what I need. another benefit with this combination is that its not necessary to have camber adjustments after lowering.
but dont let me stop you from getting the full kit as what I chose was only intended for the main purpose of my car, daily driving. and Im sure these bilsteins would work best with Sk's springs in terms of optimum handling. road or track.
yeah that's news to me. And i didn't know the bilstein and stock springs was a good combo either :domokun:
so 4 x Bilsteins are around $950-$1000 yeah?
so ..... can anyone tell me how to fit the damn front swaybar? And what are the best settings to use (I bought an adjustable one) - I take it neutral is the centre one - but what holes do I use to change what properties?
^ it's in the thread somewhere. Like soft settings front, stiff settings rear = tail happy. that's a very bad explanation, but it's the thread somewhere what settings = what driving characteristics. Some that help turn-in etc...
just use the search function for this thread with "swaybar" or something
nah Gohan I have just read the whole thread and whilst there is a little talk about sway bars, there is no explanation as to which mounting holes perform which function. Anyone know the data I need? Yes, I am a suspension Noob :action-smiley-069:
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
