  • Replies 322
Posted Images
from the first page,
Heasmans Sydenham NSW
East Coat Suspension Kirrawee NSW
St George Steering Punchbowl NSW
Centeline Thomastown Vic
Traction Tyre & Suspension Rowville Vic
Discount Tyres Service Belconnen Act
Motsons Qld
Got mine installed at TT (Vic) $350 i think, with alignment (shocks/springs/camber kits front+rear) + plus fiddling with the adj swaybars i had in there.
Very reasonable price i thought.
sent PM 7 days ago with a reminder 4 days ago .. just needed to confirm the order amount as I'm not getting everything from the kit. This is pretty fricken appalling service I must say.
If it takes more than 7 days just to get a "this is how much you need to pay ..etc" how long does it take to receive the item? I don't want to pay close to $1500 to then have to chase it up for weeks like someone's doing me a favour taking $1500 off me.
Re installation costs ... I've been quoted $550-650 by the 2 NSW places (heasmans and east coast) so a fair bit pricier than the vic joint.
Edited by Delta Force
SK gets dozens of PM's, EVERY DAY, 50+ possibly, most of it probably doesn't even pertain to group buys.... he doesn't make money off these kits and basically has offered, free, damn right impressive, advice on these forums for years. The closest thing we have to gospel around here.
Please be patient, he or matt (i think is the other guy) will get to the PM.
Centreline in Vic quoted $500, and that was a "special" price for me! Centreline sponsor SAU Vic, of which i'm a paid member (10% discount i believe) AND i also had a 20% discount voucher ONTOP of my membership. Best price? $500 :P
Traction Tyres do great work, 2 guys working on it, multiple test drives of the car, adjusted my sway bars for me as well. But for those comparing i ONLY had shocks, springs, and front/frear camber kits installed. If you're getting higher quotes, it could be because you have more stuff being done.
Once parts are sent, Toll priority are very quick.
If anyone here has got the sway bars on coilovers could they please let me know there results. Also interested if people feel happy with castor rods?
Cheers,
Lol not exactly.. Coilovers as in coilovers.. adjustable height and dampening rates etc.. As they are alittle harder than the springs im interested if big differences are noted. Im assuming they would be.
How do you find the adjustable bars with your setup then? Is it stockers or sydney kids setup?
Cheers
Nathaniel
i did SK's kit in stages.
bars first, big difference, noticeably flatter cornering
springs/shocks second, bigger difference again, car felt more planted, more stable, and cornering was even better again. Camber kits installed and setup to SK specs.
bilstein/whiteline ride is fairly firm, but felt great at Sandown...
all the damper adjustable stuff can be a bit of a wank really. Just get adjustable sway bars, that's what matters more.
what coilovers you looking at?
Ive had greaddy type s (best in japan supposedly) extremely soft which is nice however looking for more handling performance :)
So sways it is.. Any difference in feedback or rough feel?
Cheers
Hello SK,
i PMed but got no reply. I received my setup. now on the front shocks i got a small ring, bolt and washer that wasn't with the rear shocks. can you please tell me were the small ring is supposed to go?
regards
chris
I`M TRYING TO CONTACT SYDNEYKID AS HE SENT ME WRONG REAR SHOCKS AND SPRINGS...
HARD TO BELIEVE BUT TRUE
I LEFT CAR IN EASTCOASTCUSTOMS AND FEW HOURS LATER I HAVE A CALL THAT REAR SUSP. DOESN`T FIT MY CAR....
SYDNEYKID WHERE ARE YOU ??????????????????????????????????????????????????
also waiting.. paid over 4 weeks ago for a set of swaybars but no response from either Gary or Matt
i've sent about 4 PMs and i know they're online (as they are posting in threads) but they seem to not be interested in giving the goods that i paid over $500 for!
i received my goods in about 4 weeks with no reposnse so just be patient
but remember to check what u got... as i know sydneykid is ordering spring or shocks form bilstien in germany. Hopefully im not FCUKED cos only him can help me get my rear suspension....
STILLL NO RESPONSE
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
