isn't the full kit more like $2300? (with the discount)
and do R34's have front camber adjustment from factory? or, do we know what adjustments (in total) are available from factory front/rear?
  • Replies 322
Posted Images
hey sydneykit, just before i go ahead and grab a set, judging by how you said this kit would take about a day or 2 of labor, wats a ball park quote ud expect to fit these.
"Hi,
I've just had my car checked out apparently my tension rod bushs are torn.
I've got the springs and shocks from this group buy.
What do I need from this kit to replace and how much ?
Thanks"
Can someone help me out with this ?
around $500 with a professional. call your local reputable suspension experts
Interested in a front camber and castor kit delvered to perth.
Price and availabilty please.
Cheers
Availbility is - in stock
Delivery is $15
Pricing for parts is on page 1.
If you require, PM me
"Hi,
Thanks"
Caster kit, page 1
Matt, Gary,
Can you PM me an update please?
I transfered $$ to you on the 1st Aug - more than 2months ago!!
Last news I had was was about 10days ago.
EDIT: Matt, 2nd thought, call me on my mobile please.
PM and emails seem to be a hit n' miss. you'll find my number in every PM and email I've sent you guys.
hey mate, do u have a kit for a R34 GT-4? it has eye shape ends all round.
would like to have a coil-over set up so i can adjust the height to which i like.
what sorta spring rates would i get with these?
cheers luke.
cheers luke.
We have kits for the GT-4.
Best you PM me with specifics - what you want from it, budget, etc
Just wondering if say i wanted less of spring rates on Hks Coilovers am I able to get these made up to suit????
Thx In Advance
They are HKS coilovers, so the biggest issue is the shock valving, it is set for a too stiff a spring rate. Ultimately you are better of using a better shock and a softer spring rate, because by simply changing the spring rate, it will still be a crappy ride
that camber "kits"... just look like a bunch of those yellow things... after buying one of the kits, are you able to adjust anything?? Or once you put one of those yellow things in, you just run the setting SK recommended and that's it?
cheers
daniel
EDIT: just looked a bit closer, and there seems to be silver "arms" of sorts. But it only says +/- 1 degree. I just got my car aligned and the guy said the front right had -2 degree camber. Running like this, it chopped out the insides of my old tyres badly. SK has a setting of -1 camber up front, won't this be quite bad for the inside of the front tyres?
I am interested in getting a set of springs, shocks and rear camber kit for my 4door 25gt.
How long does it roughly take for the goods to get to my door from the time i place my order.
Cheers
ShanO`
Cheers
ShanO`
Roughly a week mate, PM me
  • 1 month later...
First up I dont know a thing about this topic lol but I want to lower my car, I got 3 options:
1) SPRINGS - screw my shocks? in 2days 2 decades? roughly 400-500 installed
2) COILOVERS - seemed good to me until this topic. roughly 1200-3000 installed
and now..
3) BILSTEIN & WHITELINE SUSPENSION - why are they a good choice? How much?
Now can anyone finally please give feedback on either option that they have taken. Thanks guys!
Guest
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 馃槢
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
