Hey all, Im planning on putting a new exhuast onto my R34 GTT, All im really after is a nice new deep sound, that doesnt sound over done, yet makes people look.
Does anyone have an idea or has done this..
And should i go for the chormed cannon look, or just the big twin tips out the back?
i would really love your feedback
thanks.
https://www.sau.com.au/forums/topic/88152-r34-gt-t-exhaust/
I got a 3" Turbo back exhaust with a hot dog resonator and cannon (with hi-flow cat of course). It's pretty loud in the cabin but outside its pretty cool. I got mine done at Exotic Exhausts at Sumner Park. Just note that mine is 98dB (8 over limit) but with the silencer in, it comes down to 90dB.
https://www.sau.com.au/forums/topic/88152-r34-gt-t-exhaust/#findComment-1591654
lol Choyda, ya car isnt white is it?
anyway yeah no budget, just wondering what would be a good start. i was thinking just high flow cat, back.
i was only trying to find out becuase my friend got his r33 done, and his cannon sounds like its rattling inside or something when he revs it,
i just dont wanna go half assed and get a crappy one.
https://www.sau.com.au/forums/topic/88152-r34-gt-t-exhaust/#findComment-1591794
Ya its white...
https://www.sau.com.au/forums/topic/88152-r34-gt-t-exhaust/#findComment-1592252
i put an apexi n1 catback and it sounds great and looks awesome. being made by apexi and a vehicle specific make its a neat fit and sits up high. i've lowered the car 2 inches and have had no dramas with speed humps at shopping centers at all. I hav also got the front half of the exhaust done aswell but if your just goin for a sweet note then u cant go past the n1.
https://www.sau.com.au/forums/topic/88152-r34-gt-t-exhaust/#findComment-1595861
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
