Well after months of decision i have finally bought a skyline again.3
I got rid of the Beat i bought after my origianl skyline got pinched the big VX SS gen3 V8. for another boost box.
R33 GTST
Modifications as follows;
Custom paint
(Shades blue/ green/ purple - depending on light)
Complete GTR body Kit - Minus Rear Wing
18" ANZ Chrome rims with 265-bk and 235fronts
Lowered with nismo kit
Complete 3" turbo back exhaust
High flow cat
Massive FMIC Core = 600*300*80
Custom 5" CA intake
Lighter flywheel
Lighter pulley kit fitted (complete)
Ceramic clutch
Custom gearbox - short shift
Modified Ecu to manage aftermarket mods
Turbosmart BOV (can be adjusted for sound)
Turbosmart Bleed valve set @ 9psi producing 260+rwhp
HKS turbotimer
Momo Leather/ chrome steering wheel
Momo Leather/ chrome gear knob
Pioneer head unit 50*4
VDO 8" 4 way speakers - rears (custom fitted)
Kenwood 6" 3 way speaker - front
Picks Attached.
Drove from parramatta to Sale (2 hours past melbourne) and back yesterday 22 hours driving all to look and pick up the beast.
Picks attached.,
Hope to see all of you again soon.
MSP25T - ill be getting a external gate just cause i know you love it.
Craig
https://www.sau.com.au/forums/topic/88175-im-back-baby-yeah/
Good to see you back, i still remember that night at WSID. Did your old car ever get recovered?
funnily enought i don't think so...
must be good to be back in a skyline after the commodore? :)
must be good to be back in a skyline after the commodore? ;)
BB, i meant recovered as in if the car was stripped and found.
A mate had his vl stolen and it was found about 3 weeks later stripped. He went to id it and walked straight past it, not a pannel on the thing.
nice r33
ffs when did they move sale? or did you drive to melb then back up the coast for some odd reason :D
Craig
heya dude!!!!!!!!! wow!! the car looks awesome!!! :D just need more pics in the sun so i can see the colour :D and yesss... bring on the wastegate!!! you know i love it!! can't wait to see you and your car again!!!! ;) cruise time!!!!! :P
Hi guys, no car was not recovered.
Ill be up for the curizes, and i cant be happeier being back behind the SKY MACHINE, the commy was good but u cant beat pure pulling power.
hope to see all u guys soon. my number plates are changing to PISS ON FORD (PSON4D)
You might want to do a few more engine mods (not just ricey ones like externally venting wastegate) before you get those plates, otherwise you might look a little silly when you pull up next to a Ford at the lights and get your a55 handed to you :O:)
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
