  • Replies 105
I guess im a new member so i better introduce myself...
I drive a black 32 2dr with 3inch dump, momo cat back, FMIC, boost controller + more to come... I've been driving round without a front bar for nearly 2 months now so ya might have seen me about. Keen to go on a cruise when I get my car sorted. Cheers
https://www.sau.com.au/forums/topic/882-sa-role-call/page/4/#findComment-786301
MATT,
You can count myself and the other half,we will put our hands up to be included.(Even thou im a member of s.v.d. and smasa, and occasionally cruise with the r31 boys as well)
Timmaayyy, dont be disalusioned by what you drive we dont jugde you by that were all car enthuisests who get off by the nissan make of cars esp SKYLINES your day of owning a latter model will come- be patient.My collection is growing sr20 sss pulsar(hopefully sold) 1600 dato,r31 sedan,r31 wagon and the beast when i finally get it finished!!
Regards to all,
SKYLINE (Kym)....... :headspin:
https://www.sau.com.au/forums/topic/882-sa-role-call/page/4/#findComment-786836
sooo.... how bout a cruize then? any1 keen to organize? if wee do it a down the track a bit then hopfully we will get as many people as pos, there is an autosaloon comming up i think, so why dont we try and organise 1 around then, on a sunday or something?? any 1 know when its on?
https://www.sau.com.au/forums/topic/882-sa-role-call/page/4/#findComment-787647
damn - there are so many new guys that haven't been on a cruise yet!!! Next big cruise we have EVERYONE has to turn up - and I will have name tags for the masses :)
Suggestion for next cruise: Saturday May 15th (as the wife is away) followed by pizza, 8-ball and DVDs at my place.
https://www.sau.com.au/forums/topic/882-sa-role-call/page/4/#findComment-788515
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
