  • Replies 105
I guess im a new member so i better introduce myself...
I drive a black 32 2dr with 3inch dump, momo cat back, FMIC, boost controller + more to come... I've been driving round without a front bar for nearly 2 months now so ya might have seen me about. Keen to go on a cruise when I get my car sorted. Cheers
https://www.sau.com.au/forums/topic/882-sa-role-call/page/4/#findComment-786301
MATT,
You can count myself and the other half,we will put our hands up to be included.(Even thou im a member of s.v.d. and smasa, and occasionally cruise with the r31 boys as well)
Timmaayyy, dont be disalusioned by what you drive we dont jugde you by that were all car enthuisests who get off by the nissan make of cars esp SKYLINES your day of owning a latter model will come- be patient.My collection is growing sr20 sss pulsar(hopefully sold) 1600 dato,r31 sedan,r31 wagon and the beast when i finally get it finished!!
Regards to all,
SKYLINE (Kym)....... :headspin:
https://www.sau.com.au/forums/topic/882-sa-role-call/page/4/#findComment-786836
sooo.... how bout a cruize then? any1 keen to organize? if wee do it a down the track a bit then hopfully we will get as many people as pos, there is an autosaloon comming up i think, so why dont we try and organise 1 around then, on a sunday or something?? any 1 know when its on?
https://www.sau.com.au/forums/topic/882-sa-role-call/page/4/#findComment-787647
damn - there are so many new guys that haven't been on a cruise yet!!! Next big cruise we have EVERYONE has to turn up - and I will have name tags for the masses :)
Suggestion for next cruise: Saturday May 15th (as the wife is away) followed by pizza, 8-ball and DVDs at my place.
https://www.sau.com.au/forums/topic/882-sa-role-call/page/4/#findComment-788515
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
