  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yeh fair enuff as long as it is kept in here i suppose its ok but still keep away from the double posting habit.
Oh and if u want mindless drivel y not post ure msn address? then u can talk all u want in private.
And what about Skyzerr, 5600 legitimate posts, I don't think so. 20 posts per day. And he's a moderator, so I can't see why it is ok for some and not others, I have not posted too much crap in the legitimate threads anymore.
See'ya:burnout:
Skyzer has been around since the birth of SAU and he does alot of his whoring in the wasteland. Otherwise he keeps it on track. At the rate ure going vspec u will have overtaken him in 2 months (plus he gets 2 posts for every actual post)(rumored)
Yeah, I'm not knocking Skyzerr, he can do what he want's, but seeing as I'm posting in the WA wasteland then whats the big deal. It's not like you need to moderate the Whoreland.
And since it has been created I haven't started any whoring in other threads, just joined in.
See'ya:burnout:
No big deal, its just that all the double posting should be seen in the same light a ricing and nothing more. Its not good for any1 but the person doin it.
Oh yeh, the new SWs just blow, admitted the 2nd was heaps better than the first but IMHO George Lucas is just after a retirement plan :( (GL aka punk ass sellout muther *****r)
Originally posted by GTS-t VSPEC
I disagree, I think that the original SW's was good for it's time, but people are nastalgic and don't want to like the new ones. The new SW are better all round, but can't wait till the originals are released on DVD.
See'ya:burnout:
Agreed!
Yep LOTR does kik some ass, thought it would have been better though if they broke it into 5 movies.
the first was good because nothing happens in the first 2 books apart from running around and finding food and sleeping and walking so it fit the movie well and was as full as it could be but the 2nd was too rushed and the plot could not be explained properly and with enuff depth. they needed more time, especially at helms deep.
I think reading the book spoiled it for me
IRC is for loosers.
LOTR's has been done aswell as the movies allows, there is no-way that they would be allowed to split it into 5 movies, and yes there are some areas only touched on and some area's deserve more time but they have to restrict it. I think they did a very good job, and the third movie should rock, lots of action.
See'ya:burnout:
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
