  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yeh fair enuff as long as it is kept in here i suppose its ok but still keep away from the double posting habit.
Oh and if u want mindless drivel y not post ure msn address? then u can talk all u want in private.
And what about Skyzerr, 5600 legitimate posts, I don't think so. 20 posts per day. And he's a moderator, so I can't see why it is ok for some and not others, I have not posted too much crap in the legitimate threads anymore.
See'ya:burnout:
Skyzer has been around since the birth of SAU and he does alot of his whoring in the wasteland. Otherwise he keeps it on track. At the rate ure going vspec u will have overtaken him in 2 months (plus he gets 2 posts for every actual post)(rumored)
Yeah, I'm not knocking Skyzerr, he can do what he want's, but seeing as I'm posting in the WA wasteland then whats the big deal. It's not like you need to moderate the Whoreland.
And since it has been created I haven't started any whoring in other threads, just joined in.
See'ya:burnout:
No big deal, its just that all the double posting should be seen in the same light a ricing and nothing more. Its not good for any1 but the person doin it.
Oh yeh, the new SWs just blow, admitted the 2nd was heaps better than the first but IMHO George Lucas is just after a retirement plan :( (GL aka punk ass sellout muther *****r)
Originally posted by GTS-t VSPEC
I disagree, I think that the original SW's was good for it's time, but people are nastalgic and don't want to like the new ones. The new SW are better all round, but can't wait till the originals are released on DVD.
See'ya:burnout:
Agreed!
Yep LOTR does kik some ass, thought it would have been better though if they broke it into 5 movies.
the first was good because nothing happens in the first 2 books apart from running around and finding food and sleeping and walking so it fit the movie well and was as full as it could be but the 2nd was too rushed and the plot could not be explained properly and with enuff depth. they needed more time, especially at helms deep.
I think reading the book spoiled it for me
IRC is for loosers.
LOTR's has been done aswell as the movies allows, there is no-way that they would be allowed to split it into 5 movies, and yes there are some areas only touched on and some area's deserve more time but they have to restrict it. I think they did a very good job, and the third movie should rock, lots of action.
See'ya:burnout:
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
