  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Sony 5.1 Amp/Reciever (can't remeber the model 645 or summit)
Pioneer 515 DVD (yes it's old but does the job)
Panasonic 80cm TV
Sony CS-1 SuperLite LCD Projector
Yamaha active sub woofer at the front
US Audio passive sub between the surrounds at the rear
2x Jensen front speakers
Jamo centre speaker
2x US Audio surround speakers
I used to use mine all the time, my last place had a nice white wall to project onto. It's like a personal cinema.
New place has *gag* yellow walls in the living room and I only have a crappy old 120cm screen, it's just not the same.
I'm thinking of selling mine actually seeing as I never use it now :(
Hitachi 5.1 AMP supports both DTS / DOLBY DIGITAL
Hitachi DVD supports both DTS / DOLBY DIGITAL
Panasonic Tau 80cm Flat Screen TV [farkin expen$ive]
Pioneer Linear Series Speakers [2 x 200watt fronts each with 2 x 10inch subs] [2 x 160watt surrounds + 1 x 160 watt centre].
power quotes are maximum outputs.
and, no i dont need a seperate subwoofer :uh-huh:
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
