  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
3040 bigger then 3037 right?
yeah i fink i should strengthen my box though
coz like i dun want it blowing when i start gettin up to the power output i want:)
so roughly i am after 300-400hp
do i really need to get a trust plenum for that sought of power?
adrian
Adrian,
No you don't need a Trust plenum for that, but it makes it easier to get that power. 3037 is HKS variant, they make minor adjustments to trims etc, over the garret unit. Both are around 550-600hp.
The box should be fine, how were you going to strengthen it?
See'ya:burnout:
what i meant
by strenghtening
was geta stronger box
u know like them aftermarket shifters?
but then i would rather spend the money on getting a manual conversion done ahh well auto will do for now, ah so ur using a garrett turbo smae specs as hks turbo?
but cheaper am i right?
so ur saying to build up revs in a auto, have the car in drive, and keep foot firmly on brake while reving then let gooff brake when it's time to roll?
adrian
Bully,
Seeing as your up, and I don't trust Adrian's opinion, can i ask you a serious question?
With these SAU shirts, would you like for us to organise one of each to be made so that all those interested could see what they are getting before they buy? I was thinking about one mans(L) and one womans(M), it would give people a better idea about sizes aswell.
See'ya:burnout:
Adrian, Yeah that's the best way to launch an auto.
Garret sell HKS some of there turbo's, which are only sold by HKS, therefore you cannot get a Garret turbo which has the same specs as the HKS one. But seeing as the HKS one is over $1000 more then I don't see where the real benefit is, I'd rather go for the Garret one which produces similar power.
See'ya:burnout:
troo troo good point
yeah i read bout garret providing hks turbos
and it also said who the other jap houses
got their turbos from :)
okay so the trust or subzero plenum is goin to be a 11th hour decision for me as well ;) argh i hate decisions
adrian :)
Originally posted by GTS-t VSPEC
Bully,
See'ya:burnout:
Sorry had work to do ---- i think once a few see them more will want them thats the normal thing that happens i go along with that
Originally posted by Adrian_perth
what i meant
by strenghtening
adrian
i launch mine in low then change up through 2 nd then to drive like a manual - i found i get better times that way,
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
