  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Paul... if you could find out, that would be great.
Psiker, nah, I've had a problem holding 17 psi and just lately there was a little bit of smoke after a hard run at idle.. so.. i stripped her down and took the turb into Per4manz, there was shit loads of shaft movement. practicly NO thrust washer left, and the whole thing is rooted. GGGRRRRR
it was only built 5 months ago. thats what i get for staying with the poxy stock afm.
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
    • Not sure why but RBF660/700 or Castrol SRF is listed as DOT4, not 5.1.
    • Interesting....can't say I've ever checked it, have always just changed it in the off season as practice
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
