  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
My fav song: Learn to Fly - foo fighters dunno why i love that song just do :P
Yeah i got some African American shit in my car - nothing hardcore my ex used to have the hardcore stuff and all this crap about killing their bitches, doing drugs, and killin some more was absolute crap - im sitting there thinking and this stuff u like to listen too haha major turn off!!
I've got a MOBY album. Definately have to be in the mood for it, it can be quite depressing.
I should really be reviewing EXCEL right now. I got a promotion at work, and I need to know excel inside out. They don't really know that I am pretty much computer illiterate. I never actually told them I am a computer genius...I did tell them I can work a computer, and that I could handle anything they care to give me...
I'm really in the shite. Well, I have until Monday to learn. A sickie would not be a good idea right niow. Can someone tell me if EXCEL is an easy programme? This is comming from someone who can take up to 5 minutes to find the on/off switch on a computer.
Angel excel is not the easiest program but i find throwing yaself in the deep end and learning as you go along probably the best way to do it - that way you learn what you need to know and dont get confused with a book that teaches u mindless crap and things you'll never use.
P.S - the only program where the talking paperclip is actually helpful :P
    • Yep, the plan is to do some work in Japan, as I mentioned above possibly keeping it there longer than November 2025. Frankly, I'm not dealing with TopRank ever again and, because my car is no longer with them, I could work with BBL/GY directly👍 But alas, I'm not looking at major bodywork just yet.
    • Yeah I had the probes on the battery terminals.  Sounds good. What reading should I expect to see in a car that runs well?
    • I went for the scissor lift option, gives a 3ft lift at full lift. I wanted a 2 post but my concrete wasn't deep enough to secure it properly
    • Depending on exactly where that voltage is being measured, that is most likely the battery is f**ked. If the multimeter probes are on the battery's own terminals, then it is f**ked. If they are on the car's terminals, then there is a bad connection. Either are fatal to the attempt to start it. Literally just put it on the 20VDC range, put one probe on the battery's -ve terminal (ideally not the car's terminal) and the other on the block somewhere exposed/metal, like an engine mount bolt head. You can also test the earth lead is steps, so from battery to body earth, body earth to engine connection point, engine connection point to some other spot on the engine, to see if you can isolate where a shit connection actually is.
    • I meant to write 50 originally and then double checked the price and found it was ¥12m (125k) and came to edit it and realized I had accidentally added and extra 0 in the first place lol
