  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Cool - now to find 2 more people & then I can make the booking.
You will need to pay in advance - I know it's not cheap but I certainly need the training! No point having a quick car & not being able to handle it. It will be awesomw fun as well & there is very little chance of coming unstuck - you wont even get out of 2nd gear so speeds are fairly low.
The instructors are tough (i.e. "this car should be much faster out of this corner, etc) but I reckon that's the best way for them to be.
Stuff my brown dog ( oops , animal sex , soory )
22 pages since I left.
YOUR ALL WHORES I SAY , WHORES.!!!
Micko , lifetime warranty , ho bluddy ho. If ya need a hand you got my number.
Sneeza , My ex partner ( no , not marriage partner ) , trains the ambos in driving etc. Could see if he will talk to you about the good and bad if you want.
Niz , just say the word and you could see me all you want. ( shutup:D , stop laughing . ALL OF YOU stop laughing !!:) )
phptf the times are a bit iffy but beat the rex ( blue STI 2 door this time ) . He was NOT happy cos he thought he had me.
Looks like I also got 3rd o/right with a killer quick lap .
Am doing the incar now , should be interesting ( well for me anyway )
Right , I've caught up now, you may proceed.
Cheers
slow reader
Ken
Good work Ken - when/where's the next round?
If you're not too busy tomorrow can I try your ecu? Just a quick trial will quash my concerns about power I think. Wouldn't mind you taking my boy for a lap as well since you will be able to tell straight away if he's not performing like he should.
Micko , no prob .
Will be around the house till bout 3 pm , doing the gardening , washing , painting , pool cleaning , brownie point accruing but you know all about that , unlike these single , free spirited , no cares in the world......
*sniff , sniff , boohoo bwaaaaaah
Cheers
Ken
yea so ring
* goes and gets hanky *
    • Yeah since those first 2 replies I actually went and put some 98 in it and tbf it's already doing much better than the 95 (which is weird and makes my inner tinfoil hat wearer think the 95 was a crap batch), getting 8ish around town. Again, wonder if it takes a while to stabilize if the fuel is changed a couple of times. I swear cars used to just either run "well" or "s**t* in my 20s, none of this fuel optimisation business haha
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
