  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Still think the popping and crackling on overun plus the fuel smeel is the AFM giving an incorrect signal.
It probably has to die more b4 it codes or the wiring going to it could be at fault.
Cheers
ken
Ken, I didn't see your name on Lauren, free game:p
Micko, Anything which will allow you to view the main sensors has got to be of benefit, sometimes a worn wire will cause noise on the signal which will cause this sort of strange behaviour.
See'ya:burnout:
Crackling - I'll give ya crackling...
When I got home I was listening to the idle whilst cooling down the turbos. I revved the engine a got an awesome ass explosion out of the thing - missus came out to see what had happened!!! Reckon that one would have been good for some flamage:)
Ahh ya bast*rd , was counting the posts and you pipped me for top of page.
The reason I have taken so long is the 8 pages of you trying to con Niz into coming over and/or coming across.
Bad Paul:D
they are fellow SAU members not highly desirable , goodlooking Skyline loving sex objects.
* Ken excuses himself for another cold shower *
Cheers
I have a dream
Ken
Originally posted by Micko
I believ so Paul - I will find out.
As I said Micko , you could try Eddie Wong if Jerry is unavaliable.
Ring me for his number , I think I have it somewhere.
Cheers
Ken
Originally posted by GTS-t VSPEC
Micko, If Ken thinks it's AFM related, which sounds likely, have you traced the wiring back etc, how about an oscilloscope to view the signal?
See'ya:burnout:
Yea , was thinking that but have absolutely NFI where to start on that.
Thats why I suggested Eddie Wong cos thats what he uses.
Why pauly are you a sine wave expert
To me if a wire has more than one end , I'm buggered.lol
Cheers
Hopeless sparky
Ken
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
