Originally posted by GTS-t VSPEC
If you do get offered then it might be kinda to commit them to a mental instituation:p
Have they found a cure for ugly yet Ken?
See'ya:burnout:
As i said b4 , I'm fat but can lose weight.
You will be ugly forever:bahaha:
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Most rev-head chicks ain't to special, so be careful who you invite to join us, j/k
Chicks don't like to waste money on cars, they prefer to waste it on clothes.
See'ya:burnout:
Wrong
ANY revhead chick is special cos when I was young there weren't ANY around.
They were ALL into clothes
* sob , sob *
Cheers
Ken
Tasmania - dont think so - someone show me a map please:)
The auto sparky that I went to in Joondalup had an awesome $14k diagnostic tool that plugged into the car & also had a hand held cro - misht get him to go for a drive with me. Only problem is I don't know what the signals shiould look like but i think the magic book says what output coltage ranges should come up.
BTW - you're right Ken, I am about to lose my self control. Had to restrain myslelf from putting on the steel caps & hammering a couple of panels this afternoon - Naomi told me to go and have a lie down before I got out of hand.
Ken,
When you were young the dinosaurs roamed the Earth.
See'ya:burnout:
Go to bed it's after midnight and you sure as hell need your beauty sleep
Cheers
Ken
ps , Nope , it was the ice age
my clutch is ghey. it slips above 5psi in 1st gear... grr.
so i lowered my boost.... down to like 2psi, daym, i almost forgot what it was like to drive a non-turbo. all this in an attempt to make my clutch live a little longer so i can save more fold.
come to think of it, how can a "bleeder" valve LOWER boost, if it is by definition an air "bleeder"... ho hummm...
Kym,
Sorry to hear your not feeling well. A bleeder can only drop boost to a minimum oof 0.5bar (stock boost), by fully closing it.
Sorry to hear about the clutch, you don't seem to catch a break with your car, but just think, by the time you've replaced some of these things the car will be stronger for it.
See'ya:burnout:
    • So there is no other way to remove and install the ball joints then to buy the Frenchys kit?
    • Just to close off this post with the cause of my oil consumption issues. Vertical scoring and glazing at the bottom of cylinder 6. I'm not happy, but at least I finally found something. I'll pull it and get it apart asap. Hopefully I don't need to go one size up in piston.
    • I finally got around to purchasing an actual articulating borescope. Great tool to have, I've been very impressed vs my old regular inspection camera.  With that being said, sadly I finally found the cause for my oil consumption. I always had the feeling something wasn't right but compression and leak down tests were always perfect and I had already inspected the cylinders. This time i dropped each cylinder to its absolute lowest point and with the better quality camera I found this... Bottom of cylinder 6.  Scoring looks deep and I'm presuming oil getting by caused the glazing. I already spoke with my assembler, and will be dropping it off as soon as I can pull the motor and get it apart. I'm just hoping it's not deep enough to require boring out from 86.5 ->87mm. Pistons aren't cheap.
    • I think it's the same. It all comes from the same shithole refinieries in SE Asia.
    • I was referring to the final octane level achieved once 10% ratio of ethanol is added.
