  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by 87vlt
SO WA whores are not only imbred but bullshit like crazy .... skyzerr do you have a flush button on your bottom lip?  Cause you sure as hell needs one bullshitt artist!!!
thats interesting seeing all the crap u post
i haven't seen one post from u thats constructive or helpful to car enthusiasts
try posting some useful stuff then we may take notice of u
but being a QLDer i doubt it
ok my turbo has 70,00 km on it.  the motor is 7 km old as it has been rebuilt to stock specs .... no original VL is nicer than mine ....
I win WA loses again ... other QLD on here can vouch for the condition of my car!!!!
then why was it rebuilt?
geez or moron
    • The correct answer is body colour. Admittedly it does look pretty handsome as-is in grey.
    • I'm surprised there isn't any interest in this.
    • Por qué no los dos? Body colour red with black stripes down centre, onto bonnet and bootlid.
    • From my bolts, standard M8 with 1.25mm thread pitch (M8x1.25mm).    Length is 19mm under the head and has a captive 18mm OD flat washer.   20mm length from a bolt shop is what you'll be able to get.   Make sure they're zinc plated.    If you're concerned about strength, grade 8.8 will be more than enough. Original PN is 01121-04971.  Now discontinued according to Amayama but that's because it's one of the parts that's been captured by the Heritage program, which explains the ridiculous price.   New PN is 01121-RHR20: https://nismodirect.com/nismo-heritage-bolt-pin-hinge-hood-bnr32-nissan-skyline-gt-r-01121-rhr20-01121-04971/ About AUD33 converted from Yen in the above link but that's just one example. Interesting that the hinge-to-body bolts are still available non-heritage.....PN 08116-8161G around $2 each (amayama).    Same thread but 16mm long.
    • Well, if that filter was impeding fluid flow, then it could have similar effects to faulty solenoids. The TCU will register a fault when it does something (ie, changes the state of a solenoid) and does not detect the required result. If there are other causes that can make the same lack of result, then they will be indistinguishable to the expected cause for which the TCU has a code.
